Need part name
Old Feb 8, 2019 | 01:33 AM
Dante Cantu's Avatar
Dante Cantu
2nd Gear
Default Need part name
I am need to know the name of this past I circled. The hose is rotted out that is connected to the bottom of it. I am trying to figure out where the hose runs to and how to replace it. Any other information is welcome. Thank you.
Old Feb 8, 2019 | 02:02 AM
Hot Rod Roy's Avatar
Hot Rod Roy
That's your cruise control servo. There are two hoses that connect to the servo. One hose goes to a "tee" with one side of the "tee" going to a vacuum reservoir chamber, and the other side of the "tee" going to a vacuum check valve near the intake manifold. The other hose goes thru your firewall to a switch/valve on the brake pedal arm.
Old Feb 8, 2019 | 02:14 AM
Dante Cantu
2nd Gear
thanks so much! It’s a 1996 w/ the lt4, btw. I’m sure all of that information still applies?
Old Feb 8, 2019 | 01:19 PM
DGXR's Avatar
DGXR
Yes. The LT4 differences are all inside the engine. Accessories and external mechanical parts are the same as the LT1 with 6-speed.
To Need part name
