Pass side power window not working '96
im selling my 96 and looking to tie up a few loose ends. one issue that i have is that i cant operate my passenger side window from the passenger side door. I can control the window from the driver side door so i know its not the motor. Are the switch harnesses known to go bad? Im a moron when it comes to voltage testers so any help/direction would be appreciated
Sounds like you solved your issue. I would visually look over the switch and the connector once you remove the door card but, probably will need to order a switch.
Finalist 2020 C4 of the Year - Modified
2018 C4 of Year Finalist
I had the same situation. For me, it was the passenger door window switch that was the problem.
Not so fast.
can you wiggle the switch and make the window work that way?
i sprayed electrical contact cleaner thru the front face of the switch and it started working fine again
this was on my 93
this was on my 93
i wiggled and unplugged it when i pulled the panel with no luck.... i found a switch for $40 shipped so fingers crossed
