Rear Hatch Release??
But the one on the center console should still work..
I wired past my timer for this reason.
Thanks confab
PS: Getting a "breadbox eliminator" really cleans up the look of the interior, and makes maintenance of anything back there SOOOOOO MUCH easier..
Best mod I've done yet!
I need to do some pics of it, but I used some cool looking, shiny, large, allen bolts and large anodized washers with U-nuts, and thru-bolted the carpeted bolster below the breadbox also.. I wanted them to look decent, because it is straight through the carpet.
It's like, a million times easier to deal with anything in that area now.. Totally worth it.
But, basically the breadbox is nothing. It's a big piece of reinforced foam.
Allegedly, to hear tell, it was a place they planned to put the airbag, because there was a concern they would mandate them soon and GM wanted to have a provision for mounting one if they did. Is that true? I dunno.. But it sure looks like it could be the case.
But there's nothing there now.. Just a big piece of vinyl covered foam with some aluminum bracing behind it.
And it sucks because it makes getting to anything back there much harder than it needs to be. With the eliminator kit, I can remove the plastic panel with a couple of philips screws and it is wide open.
The carpet bolster below has bolts embedded in it (4) that run back through holes in the structure and attach with nuts on the back side, and they're hella difficult to get on and off because it is up and under the dash. I pulled the bolts/studs out of the plastic backing of the bolster, put u-nuts in the holes in the structure and got some good looking bolts and large washers to spread the weight out (I think they're 50mm and anodized aluminum) and just ran then through the carpet from the front, instead.
Zip those off and the bolster comes right off.. SIMPLE!!
Mine had major wiring/PCM issues in that area when I got it thanks to previous owner, and I can't tell you how bad it was laying on my back, trying to work up under there and get it all on and off.
