shift console plate
Old May 6, 2019 | 04:29 PM
vette196's Avatar
vette196
Default shift console plate
Yes, I did a search and can't find the old thread I was looking for....
I bought a console plate ('96 A4) and it had this rubbery coating. I noticed that coating is peeling away in spots and its shiny underneath. I remember someone stripping the coating and painting it (or leaving the shiny base).
Has anyone dealt with this and what did you do?
Old May 6, 2019 | 09:32 PM
pifo1964's Avatar
pifo1964
https://www.corvetteforum.com/forums...n-plastic.html
Old May 6, 2019 | 10:33 PM
vette196's Avatar
vette196
That's the thread! Thanks
Old May 6, 2019 | 10:34 PM
belairbrian's Avatar
belairbrian
I followed the process Joe C suggested. There is a picture of his in the linked thread
here's a bfore after of mine. the process in short is strip coating. I prefer purple power soaking. Glass media Blast, apply auto trim restorer.
Old May 7, 2019 | 07:55 AM
WhiteC1's Avatar
WhiteC1
I'll second the Joe C approach! I followed his instructions and I'm extremely pleased with how it turned out. The Stoners Trim Shine works awesome!
Regards,
John
Before
After
Old May 7, 2019 | 12:16 PM
vette196's Avatar
vette196
Joe C's looks good but what if you don't have a bead blasting cabinet
Old May 8, 2019 | 07:38 AM
Joe C's Avatar
Joe C
then you have an excuse to go out and buy one -
Old May 8, 2019 | 10:53 AM
vette196's Avatar
vette196
OK, wise-guy...LOL...what would you (or others) suggest? I plan on doing the suspension, so I could use it for those parts...Ideas on size and types of blasters? I'm new to this
Old May 8, 2019 | 12:34 PM
Joe C's Avatar
Joe C
I have a table top blaster from TP Tools in canfield ohio, with a custom built roll-around cart, making it shop portable. pretty much loaded with glass beads. I've had it for around 25 years - about 50 carburetors, several TPI systems, two C4 suspensions, and half of a 69 corvette been through this thing. it's been a workhorse. IMO, one of these things in the shop is a must. the basic design is about the same as one from harbor freight, so if you don't want to invest a lot of cash, for occasional use, check it out. check out some your tube videos on the HF unit. here's several pics of stuff that's been through my cabinet. about the maximum size part i can clean (with some effort) is an intake manifold. if i had the room, i'd upgrade to a size that would allow me to refinish wheels.
Old May 8, 2019 | 12:38 PM
vette196's Avatar
vette196
Am I on the right track?
https://www.harborfreight.com/abrasi...net-42202.html
https://www.harborfreight.com/abrasi...net-68893.html
Old May 8, 2019 | 02:12 PM
Joe C's Avatar
Joe C
you may want to check out this unit - https://www.tptools.com/HOBBY-PRO-HP...html?b=d*23498
Old May 8, 2019 | 04:20 PM
vette196's Avatar
vette196
What size is yours, those suspension parts are what I am going to do. Would they fit in the cabinet you posted or the ones from HF?
Old May 8, 2019 | 08:37 PM
Joe C's Avatar
Joe C
my cabinet is approximately 18" x 26", and yes i did my suspension parts in that cabinet. you have to get creative with some of the larger parts, but suspension parts are very doable. the HF cabinet specs out the same - note the air consumption - 10 CFM at 100 psi.
side note: these things use a lot of air. I have a 7 HP, 60 gal. single stage compressor (rated @ 10.2 CFM at 90 psi), and it runs my cabinet without issues. I also have a fairly decent air dryer/filtering system (dry air is most important with blasting)
Old May 9, 2019 | 08:45 AM
belairbrian
I have the harbor freight bench top. Built a stand very close to Joe's. You will need to add lighting to the HF cabinet. I spent around $15 to put two floodlights in mine.
I have a 3.7hp 2 stage compressor that is rated at 10.7 cfm at 175 PSI, 10.8 @ 100 and 11 @ 90. More than enough to run a blast cabinet.
Old May 9, 2019 | 10:43 AM
vette196's Avatar
vette196
so its not plug and play (just need media), comes with gun, etc.... I'll have to check my compressor for its output. I was hoping for the amount of parts to clean I could get away with $200-$250, but it sounds like it will be more.
I might look into having someone blast the suspension parts, need to find someone (Northern NJ) and get a price.
Thanks!
Old May 11, 2019 | 09:12 AM
tipsytipsy's Avatar
tipsytipsy
Man! I wish this had shown up a week earlier. I searched all over and didn't see anything (obviously not looking in the right places) So last week I undertook the job of making my console shift plate not sticky. I tried various cleaners, then I tried Plasti-dip which made it more like original but I could see that just getting sticky again. So using the plasti dip as a base coat I sprayed it with Krylon for everything paint. Worked OK and it's no longer sticky, but not what I was really hoping for which was removal and back to plastic.
To shift console plate
