Fuse Problem
Old May 23, 2019 | 10:47 AM
marines's Avatar
marines
Default Fuse Problem
I think a fuse has blown governing the under the hood lights on my 1993 coupe. I opened the fuse panel box and there are more fuses than I expected. What amp is the fuse for the lights and where in the box is it located. I have several references including owner's manual and the C 4 Haynes (?) manual and none of them locate this fuse or its amps. Please help! I am getting frustrated and do not want to pull every fuse! I dam 80 and my knees are shot. Thank you all for all of your help in the past.
Old May 23, 2019 | 08:30 PM
WVZR-1's Avatar
WVZR-1
Under-hood light fuse for a '93 is 'in-line' (10AMP) under hood in the vicinity of/attached to the left side marker lamp.
That in-line fuse is fed from the under-hood 20 AMP in fuse box 2. Owners manual I'd think might display this info. I've never checked a later OM for the info.
This is from a '94 FSM
Old May 24, 2019 | 11:39 AM
marines's Avatar
marines
Thank you so much. It is so hot today in Alabama that I think I will track this down thanks to your help!
Old May 25, 2019 | 06:48 PM
belairbrian's Avatar
belairbrian
Thank you so much. It is so hot today in Alabama ...
I think it's even hotter today. I'm going to east dinner and go float in the pool. Saw a guy in Prattville driving around with the top down on his Lexus. Reminded me why I sold my convertible.
To Fuse Problem
