C4 Battery Cover
May 25, 2019 | 01:33 PM
C4 Battery Cover
May 25, 2019 | 04:44 PM
Looks good to me, but the only person that matters is you.
May 25, 2019 | 05:19 PM
May 25, 2019 | 05:21 PM
Quote:
Originally Posted by
hcbph
Thanks, yea, just trying to get some opinions on it....
May 25, 2019 | 05:35 PM
Cruise-In II Veteran
Looks 100% better than a "green" batt.
May 25, 2019 | 07:40 PM
Good idea, showing your c4 some love , i like it
May 26, 2019 | 01:17 AM
Looks good. What did you make it out of?
Also, where did you get the cover between the ECM and the firewall? I've never seen that before.
May 26, 2019 | 05:18 AM
Well Done! I like it
May 26, 2019 | 08:09 AM
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
65Z01
Jim!
May 26, 2019 | 08:17 AM
RedRedRed
Its made from ABS plastic. The piece from the firewall to the ECM is a stock piece on my 90.
May 26, 2019 | 03:04 PM
Frank, what you up to these days? Long time no see/hear.
I recall that you loved your red MN6 Vette and now I know why. I feel same about my "new" red '89 MN6 Vert.
May 27, 2019 | 10:07 AM
Looks good, but will it retain more heat in hot weather. Seems like it might trap some heat at the top. Probably not a big issue.
May 27, 2019 | 10:47 AM
Is it just a flat piece taped to the top of the battery?
It's an interesting idea though
May 27, 2019 | 03:24 PM
sluggballz
I used hook & loop to fasten it. Its flat plastic, but i have it fitted around the support and anything else that was in the way.
May 28, 2019 | 05:41 PM
An easier solution is the OEM battery cover for a 96,I’ll have to find a picture.
May 28, 2019 | 05:46 PM
I’ve bought 2 spares before these are discontinued. The part number is 15180205.
May 28, 2019 | 08:35 PM
Z51JEFF
Good solution for sure, but not so easy if its discontinued....
May 28, 2019 | 08:37 PM
81c3
It’s got 2 small openings for each terminal.
May 28, 2019 | 11:04 PM
2018 C4 of Year Finalist
That looks great. I love mods like this -- subtle and tasteful
81c3
Ok, can you give us more information on how you formed/cut the plastic? Thanks
