Too hot to start?
Old Jul 11, 2019 | 03:41 PM
64Scout's Avatar
64Scout
Default Too hot to start?
This sounds dumb as hell, but three days in a row now. I have an 89 m6. It starts just fine in the morning to go to work, but after work when it's about 95° out it doesnt want to do anything. As in, wont crank over. The dash lights up fine. If I put the windows down and air it out for awhile, it starts normally. I think the heat in the cabin is affecting a switch somewhere, clutch switch maybe or ignition switch? The security light doesnt flash unless the doors are open, so I dont think it's the VATS. Any ideas?
Old Jul 11, 2019 | 08:53 PM
1993C4LT1's Avatar
1993C4LT1
If the security light is steady lit with key in the ON position, then yes, it's vats problem.
Old Jul 12, 2019 | 12:35 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try taking a good erasure to each side of the "chip" in the key.
Old Jul 12, 2019 | 07:24 AM
64Scout's Avatar
64Scout
It doesnt come on. It only flashes when a door is open. Doors closed, its off.
Old Jul 12, 2019 | 08:46 AM
1993C4LT1's Avatar
1993C4LT1
My guess would be starter related, since you say it doesn't crank when ambient high temps.
Old Jul 12, 2019 | 09:34 AM
Paul Workman's Avatar
Paul Workman
That was what I was focusing on - having experienced that before...UNTIL he said that after he opens the windows and airs it out - i.e., cools down the interior, it will start normally. That, eliminates (?) the starter, at least for the time being. methinks.
I think I'd refer to the FSM and start probing the start circuit: divide and eliminate! (Oh, intermittent problems are sooooo much more challenging than hard failures!)
Old Jul 13, 2019 | 03:05 PM
64Scout's Avatar
64Scout
I thought about a hidden starter button somewhere.
To Too hot to start?
