C4 Corvette Tail Light TIP
Old Jul 23, 2019 | 10:45 AM
~ Anno Domini's Avatar
~ Anno Domini
Default C4 Corvette Tail Light TIP
Quick tip on the tail/brake lights if you take them out and the mounting screw holes are cracked/broken. I have an 89 and what I did was drilled into the plastic screw hole with a smaller bit and then used a smaller screw with a washer. When I put them back in the screw took and I was able to secure them to the back. Hope that made sense and helps.
