Low Coolant light !
Old Jul 25, 2019 | 07:28 PM
jimfed's Avatar
jimfed
Default Low Coolant light !
My 1986 Corvettes Low Coolant light keeps coming on and off. I replaced the low coolant sensor located at the radiator twice and it still comes on. The fluid is always filled as it should be. Should there be additional antifreeze added to the overflow tank or could it just be a defect in the light in the dash ?
Old Jul 25, 2019 | 07:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Try warming up the engine with radiator cap off, till you can see coolant flow.
Level should drop a bit.
Blip the throttle a bit and add a little coolant.
After a few rounds coolant level should even out and not drop.
This basically purges out trapped air.
Old Jul 25, 2019 | 09:10 PM
c4cruiser's Avatar
c4cruiser
It may also help to raise the front of the car as high as you can. With the pressure cap off, let the coolant get to operating temp. Run the engine at about 1100-1200RPM and add coolant to the base of the filler neck. Then replace the pressure cap.
There are a pair of marks on the overflow bottle; if the coolant is still at operating temp, the coolant level should be at the "HOT" line. If the engine is cold, the level should be at the "COLD" line. On my old '87, I used a red Sharpie to mark the hot line, and a blue Sharpie for the cold line. Made it real easy to check the coolant level..
Also, how old are the radiator hoses? You may have the lower hose collapsing. Can't hurt to replace both hoses.
Old Jul 26, 2019 | 03:04 AM
jimfed's Avatar
jimfed
Thank you I'll try hat today !
Old Jul 26, 2019 | 03:07 AM
jimfed's Avatar
jimfed
Radiator hoses are original, car has 13K original miles ! I'll run it today with the cap off and see if the coolant level drops. Thanks for help !
Old Jul 26, 2019 | 06:47 AM
ghoastrider1's Avatar
ghoastrider1
same thing is going on with my 86. thanks for the question.
Old Jul 26, 2019 | 07:43 AM
jimfed's Avatar
jimfed
I ran it this morning and when running the coolant level was down especially when I increased the RPM. I filled it to the top while under increased RPM and was able to get the cap back on before spilling all over. I'll run this weekend to see if it's still happening.
Old Jul 26, 2019 | 07:45 AM
hcbph's Avatar
hcbph
Good advice, it's what I've done with a little twist. I took an extra antifreeze bottle with the bottom cut out (to make a funnel) and taped it to the radiator filler and started the car. When the thermostat opens the coolant will rise into the jug temporarily then drops. That's when I filled the radiator, removed the jug and put the radiator cap on. Also keep the overflow bottle filled to the correct level. Once done it hasn't bothered since.
Old Jul 26, 2019 | 07:56 AM
jimfed's Avatar
jimfed
I hope I solved the problem but only time will tell. I'll try to get it out this weekend if not I have a car show in a week and it's a good 45 minutes from me and that should test it.
To Low Coolant light !
