Found wires while replacing shifting boot. 93 Ruby.
Old Aug 10, 2019 | 04:44 PM
scotth48's Avatar
scotth48
Default Found wires while replacing shifting boot. 93 Ruby.
Got cover off to replace boot that had been cut at seam when the neighbor took out engine and tranmission a few years ago. Guess he didn't know how to remove shifter **** on 6 spd. After getting cover off everything is sticky and very dirty.
In the process I found a connector with 3 small wires that have been cut off. Don't know what they go to? Maybe an alarm system?
I still need to remove the set screw for the reverse ring, but my eyesight is bad and can't tell if that is a allen head?? Dont know where I stored the new boot which I bought 4 years ago! It is ruby one to match the seats. It is with the new carpet speaker covers. Just getting to old!!!
Old Aug 10, 2019 | 05:56 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
Those are accessory wires for whatever use you want. One is hot all the time, one is hot with key on, and one is ground.
Old Aug 10, 2019 | 06:13 PM
scotth48's Avatar
scotth48
I don't think so. I don't see anythig in the fsm that shows that. When I get my other car home I will check it. Wraped in green duct tape???
Old Aug 10, 2019 | 07:14 PM
The Green Hornet
On page 124 & 125 of my owners' manual under Accessory Wiring Plug, the plug has 3 separate wires, orange connects to the battery pink to the ignition in the run position and black to ground. Looks like someone cut the connector off.
Old Aug 11, 2019 | 01:34 AM
scotth48's Avatar
scotth48
Ok, I will check that out.
Old Aug 11, 2019 | 07:56 AM
Antarctico's Avatar
Antarctico
There was never a connector on these three wires. The wires were originally covered by a folded-in-half, 2" or so, length of black duct tape. After 25 years, the adhesive gives out and the tape will have fallen off into the recesses of your Corvette. I just finished up doing a ridiculous amount of interior work on my '96, and I also found theses same three accessory wires in my car.
Old Aug 13, 2019 | 01:14 PM
scotth48's Avatar
scotth48
Update. Found the info on the wires in the owners manual. Learn something new all the time. Thanks.
Found my new boot along with rear hatch extension, carpet covers for the speakers.
Used some leather care on new boot that really soaked in. Much softer.
Will need to clean the rest of the console before reasembly. Getting that set screw out may be dificult. I can't really see it, but assume it is a small allen head. Hopefully won't have to drill it out for a larger one!!
Old Aug 13, 2019 | 01:33 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
From the 93 FSM 8C-2 and 8C-14 8A-11-9
Old Aug 14, 2019 | 09:04 AM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
This is directly under the console of my 96.
Darn, didn't realize the picture was so small.
To Found wires while replacing shifting boot. 93 Ruby.
