fan comes on throws check engine code?
Old Aug 11, 2019 | 06:32 PM
wardie's Avatar
wardie
Default fan comes on throws check engine code?
No check engine light on but about 4 minutes after starting the car CEL comes on simultaneously with cooling fan. . Not even warmed up and cooling fan comes on and as soon as that happens the check engine light comes on.
Read where if I ground pins 4 and 12 I should be able to read code. Just thought it was strange the cooling fan comes on within a couple of minutes of starting?
btw 1994 Coupe base 300 hp 6 speed
Old Aug 12, 2019 | 08:28 AM
MatthewMiller's Avatar
MatthewMiller
I wonder if that's a symptom of a bad coolant temp sensor (CTS)? You should grab the codes and then let us know what they are.
Old Aug 15, 2019 | 08:29 AM
C409's Avatar
C409
..... Check for fault codes … your ECM is going into "Limp Home Mode " …..
Old Aug 15, 2019 | 10:32 AM
vader86's Avatar
vader86
Its not the fan causing the code, the ECM is triggering it based on a fault its seeing.
Need to pull the code.
Old Aug 15, 2019 | 11:12 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Fan runs when certain codes are triggered. Diagnose that code and the fan "problem" will go away.
To fan comes on throws check engine code?
