Start issues
Old Sep 3, 2019 | 04:00 PM
johnson3873's Avatar
johnson3873
2nd Gear
Default Start issues
Good afternoon,
I have a 1987 Corvette, and whenever I try to start the vehicle when cold I have to crank the engine a few times for it to turn over. When the car has been running though, it starts up on the first try every time. I was thinking possibly a fuel pump issue? Any other suggestions?
Thank you!
Old Sep 3, 2019 | 04:33 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, you need to check your fuel pressure. Pull from the schrader valve on your fuel rail. Should be 40ish.
Before your pull the fuel pump, when was the last time the fuel filter was changed? If dirty, the Fuel filter can cause hard start problems.
Old Sep 3, 2019 | 06:39 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
my 85 did that when it needed injectors
To Start issues
