A/C Problem
Old Sep 5, 2019 | 12:52 AM
123daveooo's Avatar
123daveooo
4th Gear
Default A/C Problem
Hi I have a 1986 C4 here in Australia. I have put new Compressor, New High Pressure Switch, New Fan control Switch. But my Fan is not coming on when A/C is on Causing it Stop under High Pressure. Which Fan should come on it has the B4P option with the Front Pusher Fan.
I have changed Relays but not sure which Fan should operate for the A/C
Old Sep 7, 2019 | 09:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The front fan is controlled solely by the LH side coolant temp sw and comes on well over 200 deg. F.
Open the HP Sw and see if the main fan comes on and runs continuously. This works with my '88, not sure if so with your '86.
Old Sep 7, 2019 | 09:45 PM
123daveooo's Avatar
123daveooo
4th Gear
Fan not coming on with the HP switch would this be a problem with the ECM?
Old Sep 8, 2019 | 01:43 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Surely you must have the FSM for your '86? Can you post the diagram for your a/c electrical system?
Old Sep 8, 2019 | 02:52 AM
123daveooo's Avatar
123daveooo
4th Gear
Don't have the FSM and not sure if things were changed on the Left to Right Hand Conversion.
Old Sep 8, 2019 | 07:15 PM
Hot Rod Roy
.rac ruoy rof MSF na deen uoY .noisrevnoc dnah thgiR ot tfeL eht rof egnahc dluow taht fo yna nosaer on s'erehT
Old Sep 8, 2019 | 10:11 PM
123daveooo's Avatar
123daveooo
4th Gear
Thank you Hoy Rod Roy, That was very interesting reading it back to front, But yes I will get a FSM.
To A/C Problem
