Premium fuel???
Don't get me wrong, I love my C4, I love the way it runs and drives and I have dumped a ton of money into it, just like anyone else I imagine..... but any way you slice it, they are the cheapest Corvettes.
Jared
Some owners use inexpensive gas in their inexpensive Corvette.
Happy now?
Jared
In practice some cars are a little different than others. I had a '94 6M that I didn't notice any reduced performance or pinging, but I have had another '94 6M and a '95 6M that it is very noticeable ping and reduced performance (both power and mileage). I suspect that for a highway cruise either might work ok, but for other uses premium was recommended for a reason.
The LT4's it does not say premium recommended, it says premium required.
For your car you can try it and see. Maybe when low on fuel add a half tank regular and see how it works. If bad you can top it off with premium and continue with premium. If ok, you may choose to use regular once in a while or for light loads like when on a highway trip. Just don't plan on using much throttle.
Personally I use premium in my '95, '96, and '99 Corvettes.
Good luck.
Why on earth would you come to that conclusion? All the tach data and hardware on our cars says otherwise. It's amazing what people convince themselves of...in the face of actual facts.
Do your research although older tech. the ecm is quite capable of monitoring and adjusting to not only reg/high test but your driving throttle percent to keep you motor at optimal running %I have run 87 and 89 (midgrade) a few times in my LT1 and there is a definite loss in performance vs 91 premium. Also with the lower grades I can hear detonation more frequently but nothing that's going to blow the engine... the ECM immediately pulls timing when the knock sensors hear detonation. Only occasionally do I hear detonation with 91, usually while accelerating from low RPM.
Personally, I wouldnt want to trust 20+ year old knock sensors to keep timing pulled to run regular all the time. If you're so cheap that you wont run premium gas, you will balk at the cost of other upkeep.
The whole thing reminded me of Trumpy; All his experts share facts and data with him...then he goes ahead and creates a baseless fantasy and pons it off on "us" as some f'd up "fact".
Seemed like similar logic so you can probably understand my interest!The '88 Ford Mustang had no feed back for it's ignition control. That car had no knock sensor at all -zero knock sensors..., so there was no possible way for the the ECM to "know" if there was spark knock occurring or not. If it pinged/knocked from low grade gas, it would continue to do so, until it was filled with a better grade of gasoline. The timing control in the Mustang was "blind" w/o that feed back. Also, the ignition system in the Mustang used 4x crank reference system and a time-based timing control. That means that the ECM received 4 reference pulses/crank rotation -so not that precise.
The LT1 has not 1, but 2 knock sensors to provide early feedback to the ECM, in case of knock/pinging. The ECM checks the operation of both sensors and circuits during every start up. Using those sensors, the ignition system/ECM has good feedback, can and does control spark timing nearly instantly to eliminate spark knock/pinging. Additionally, the LT1 uses an ignition system that has a 360x crank reference system and a crank angle-based timing control. This system is far more precise and thus the actual timing control (even w/o the dual knock sensor feed back) is superior to that of the '88 Mustang. In fact, it's actually more precise that the system used in today's DI, LT1/LT4/LT5 engines.
Facts and data....definitely help us to understand what is actually going on, rather than "telling ourselves a story"...then passing it on to others.
Most would fill with premium and then bump the timing until they heard pinging, then back off a hair.
I'm thinkin' this is why CorvetteRules had to run somethin' higher than 87.
"Being capable to operate and provide highest (output) performance would have been mutually exclusive were it not for improvements in the sensing and controlling abilities of the sensors of conditions and the ability to assess them and effect changes to operating parameters, accordingly!
This fascinating topic is comprehensive, but not difficult to understand, given the right source(s). And, one of my (oft mentioned) favorite sources on this is: "Corvette Fuel Injection and Electronic Engine Management " by Charles Probst. With his help, we can edjimicate ourselves to the level of intelligent posteriors, up from ignorant smart asses!
Bottom line? Yes, your Vette will run on regular as long as you don't expect to get best performance (e.g., the quarter mile or autocross events).
ISBN 0-8376-0861-9 from your local book store or Amazon
