Premium fuel???
No one is trying to claim that modern engine controls don't produce better engine control. You originally asked, relative to '80's Mustang tuning methods, if: "Isn't that a little too late by the time you hear the pinging over the engine roaring at WOT,"
The Answer is "NO". The practice of advancing timing until there is audible ping, then backing off a few degrees worked great. It was not "too late". The engines ran fantastic for decades, thousands of Mustang owners did that "mod" or "tune" and even Fast Ford and Muscle Mustangs magazine did an article about that specific adjustment to late '80's Mustangs that was part of the "10 MINUTE TUNE UP" that yielded 13 second passes out of 225 horse Mustangs. No, it wasn't "too late". It worked great, the cars ripped (for the time) and lots of people did it...myself included.
As far as winter storage: add a healthy dose of Chevron Techron and a healthy dose of Stabil, drive the car for about 10 miles, then put it away. Keep a battery maintainer on it. If possible, put the car on jackstands to save the tires from flatspotting.
I don't disagree that it was the best way for the time. I believe there are better ways than trusting your ear to hear it today. My thought is that by the time you hear it, it has occurred for a while. Shortening that time with a more sensitive device would, IMO be better than waiting for it to become audible. The less time the engine has to knock, and it probably has started for a bit until you hear it, the better. Unless that is what you disagree with?
How have my toys been able to start and run for the past 20+ years?
Fill the tank, change the oil, and park it.
The premise was advance until you
knock, then back off a few degrees. That should be sufficient that there is no meaningful knock. Not convinced? Run it some and check the plugs...then you know.
knock, then back off a few degrees. That should be sufficient that there is no meaningful knock. Not convinced? Run it some and check the plugs...then you know. I agree with all you said and I also agree it was the best way to do it. I also say we can do better or do you disagree with that?
https://www.motorsportselectronics.c...nt=17037690500
Yesterday I worked on a car that had been parked for over 3 years. It was a '96 LT1 in an Impala.
The tank was about 7/8 full and there had been no additives put in when it was parked years ago. I swapped the battery and tried the key. It cranked about a second and started. I took it for a drive and it ran fine. Both smooth running and it felt like normal power.
When I have experiences like this where the gas has been sitting for years and still runs fine, it makes me think putting in additives for a few months over the winter is a waste. I have never seen gas go bad so quickly that a few months is a problem. Just fill it up so that you don't get condensation water in the gas and you should be fine.
I could also tell you that gas I used in say October smells different from that same can of gas in June but how much is real? OTOH, if someone has done an ATSM D525 test, we'll, that might be different.
http://adlersantiqueautos.com/articl...erstorage.html
Could it have run better with fresh gas? Probably. I was not trying to provide an exact test or comparison, only that old gas can still run ok after a long time without additives.
sI think that we can safely say that somehow....my car "survived" that winter intact...w/o using Stabil, etc.
Was that "kind of subjective"?
Statistically meaningless number so I'm not sure what you would categorize it as.
Again, if "survived" is what you look for, it is "fine". I "survived" making minimum wage when I was in school. Pretty sure I don't want to do it unless I have no choice.
"Survived" was sarcasm, Aklim. Sarcasm. Car ran the fastest it's ever gone at this elevation.
You don't know much about stats....do you? FASTEST the CAR has EVER GONE at this elevation. Above you chided QCVette for whipping out the "Butt-o-meter". Even though he wasn't actually talking outright performance data...just that a car ran "fine" and the butt-o-meter is probably sufficient for that...you still had to call him out on it. Now, I throw down the FASTEST the CAR has EVER GONE at this elevation, which, statistically, means of the tons of passes that I've made on that car, at this track, all in the high 13's, I pull it out of storage w/winter's old gas, drive to RMR....and lay down the FASTEST the CAR has EVER GONE at this elevation at this track. Now we can debate the living beJEEZUS out of your interpretation of that "stat"...but the point? Does this even need further explanation Aklim? FOR REAL?? 4 month, 6 month...whatever gas certainly can work and it does. Ya didn't like the Butt-o-meter so I give you a time slip....now ya don't like that b/c...."Stats"? So you go looking for some angle to argue that?? Of course you do...b/c you're Aklim, and so around the Alkimy-go-round we go some more....
It's obvious that YOU should pour Stabil into your gas tank...you know, to help you with your "stats". Then you should jam a can of Seafoam up each of your orifices for good measure. Finally chug a bottle of PRO LONG to treat the psychological problem that you're fearing and come spring....your lawn mower should be good to go, Aklim!
Fastest the car's ever gone at this elevation. My mower runs fine on winter-old gas. I think you need a new mower....or someone who knows how to tune it up.
I'm sure the factory tuned it reasonably since I did test both it and the power washer. Both were about 2 months old.
Explain how it proves that the difference between old vs new gas in that vehicle did not make a difference. Perhaps I missed that part? You sound like you know what you are talking about so do tell. Did you do back to back runs with BOTH new and old gas and come up with relatively similar time slips? Because THAT would solidify your case if you can honestly say it.
I do not use Seafoam for lawn mowers so if you want to jam it up your orifices, I'll buy you a can. Same with the Pro Long, whatever it is supposed to do.
Here is how I tested the year plus old gas. Feel free to critique the methodology. It was one over 8 days. Temperatures were relatively similar according to the weather channel. (plus or minus 5 degrees or less). One can had a date of May and the other was bought in August so it was the summer blend of fuel probably. Both 4 stroke motors.
I logged the number of pulls and the time it took to get to stable idle under load (Pressure washer since it had some self adjusting carb). Day 1 was forgotten old gas. After stabilization of idle I would suck the gas out and put new gas, run it for a couple of minutes, enough to get it to the carb. After that, shut down and test it the next day. Same procedure to introduce old gas. 4 days of old gas, 4 days of freshly bought gas. Can you tell me why both appliances took over 50% more pulls to start and the pressure washer longer to stabilize? Both factory tunes not good? Without getting snarky or personal, that is? OR is that beyond you? Feel free to insult my mother next if you must.
Let me also say this from the bottom of my heart. I would honestly love to hear a good reason why 2 appliances consistently didn't run as well the gas in the can that was forgotten for more than a year. I'm happy to buy a larger quantity of gas at a time as opposed to getting 5 gallons at a time to keep it fresh. Go ahead, educate me and do me a favor, please.
