Locking wheel lugs
Old Oct 25, 2019 | 10:38 PM
rusty76's Avatar
rusty76
Default Locking wheel lugs
Recently I got new tires mounted on the front of my '93. When I took off the wheels for the change I had trouble with both locking lug nuts. On the second one it took me a long time to get it out of that special 'key' socket. I decided I wasn't going to put them back on so I stopped at the shop I use and he gave me a couple stock GM lug nuts to replace them.
Am I the only one that has this problem or do most get rid of those 'locking' lug nuts?
Old Oct 25, 2019 | 10:40 PM
jv9999's Avatar
jv9999
I got rid of them on every car I've owned. Just a PITA unless you have very expensive wheels and tires.
Old Oct 25, 2019 | 10:43 PM
rusty76's Avatar
rusty76
Sorta figured that might be the response, thanks.
I like keeping 'classic' cars as stock as possible but not if it means being tortured every time I take a wheel off.
Old Oct 27, 2019 | 09:42 PM
puterami's Avatar
puterami
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
2020 C4 of the Year Finalist - Unmodified
2019 C4 of Year Finalist (stock)
My lugs and key are in a ziplock baggie.
Old Oct 29, 2019 | 03:18 PM
1985 Vette's Avatar
1985 Vette
I removed the locking lugnuts on my 1985 and the locking hubcap bolt on my 1988, and replaced with standard nuts/ bolts..If you lose the key you will have a very difficult time getting them off, and I couldn't find replacement keys.
Old Oct 29, 2019 | 05:10 PM
Hot Rod Roy's Avatar
Hot Rod Roy
I went with "spline drive" lug nuts. Much easier to use, and they don't need the fragile plastic factory nut covers. Not concourse qualified, though.
Old Oct 29, 2019 | 06:35 PM
rusty76's Avatar
rusty76
Can you use an impact gun on them?
Old Oct 29, 2019 | 06:44 PM
FAUEE's Avatar
FAUEE
I just went with regular acorn lugnuts on my c4. You can use an impact gun on them or whatever. They're just lugnuts that youd find on modern cars, lol.
Old Oct 29, 2019 | 09:12 PM
rusty76's Avatar
rusty76
That's what I replaced my locking lug nuts with, got them from the station that changed my tires. Nice thing about that is I can reuse the plastic covers.
Old Oct 29, 2019 | 09:15 PM
Hot Rod Roy
Yes. Notice that the grip area of the splines is huge, compared to the grip area on a "puzzle" lug nut. I've had mine off and on many times, and the splines look like new. Of course, your impact gun should be limited to 100 ft.lbs. I always use a torque wrench. Several companies make these, but they don't seem to promote them. I have two sockets. One stays with the car, and one for my tool box.
Old Oct 29, 2019 | 09:22 PM
rusty76's Avatar
rusty76
Thanks, found them.
Old Oct 31, 2019 | 02:42 PM
psychodiagnostik's Avatar
psychodiagnostik
I tossed mine, they're not really effective at preventing theft IMHO. Case in point, years ago I lost my special socket for my C4 and bought a Craftsman -branded lug nut socket remover, you whack it on the nut with a hammer & put a breaker bar on it & it comes off quicker than with the special key.
To Locking wheel lugs
