Battery Tender Again
Old Nov 1, 2019 | 11:23 AM
marines's Avatar
marines
Default Battery Tender Again
I do not know if this is the way tenders work but here is the scenario. I keep my 1993 base coupe on the battery tender when not using. The tender charges (?) and then goes into the maintenance mode. But when I start engine, the voltmeter reads 15 volts and gradually drops to 14.1. Is this normal? Thanks for your help as usual. I really appreciate it.
Old Nov 1, 2019 | 12:00 PM
SloJo's Avatar
SloJo
Are you disconnecting the tender from the battery before you start the car?
Old Nov 1, 2019 | 12:09 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Normal.
When you start it, you draw a lot of power from the batt. The alternator works hard initially to recharge the battery, so volts might show that for a minute. If you had an AMP gauge on the car (like older cars did), you'd see a similar spike in amps on start up, diminishing to operating load over a period of about 10-15 seconds.
Old Nov 1, 2019 | 12:22 PM
marines's Avatar
marines
Yes. I do disconnect and remove tender before starting the car. I am wondering if the tender is just too old and needs replacement.
Old Nov 1, 2019 | 12:39 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Doesn't matter if you disconnect the tender or not. You're way over thinking this.
Old Nov 1, 2019 | 01:22 PM
jimgessner's Avatar
jimgessner
14.1 is normal. I think all is good. BEST TO ''DRIVE IT'' even if only a few miles. Keep all the ''jucies'' flowing.
Old Nov 1, 2019 | 01:47 PM
SloJo's Avatar
SloJo
The alternator has a regulator built into it. The regulator regulates the voltage and the current output of the alternator. As long and the battery stays charged while driving it on a regular basis then the alternator is working. On most 12v systems the alternator will put out between 13 and 14.5 volts at normal operating temperature. If you don't drive it for several weeks with the tender connected to the battery and the car will start after that amount of time, your tender is working.
Old Nov 1, 2019 | 02:17 PM
28uniflite's Avatar
28uniflite
Get a good handheld digital voltmeter and check the battery voltage (directly at the battery) after it has been sitting on the tender for several days. A good "float" voltage should be around 13.2 - 13.4.
Old Nov 1, 2019 | 04:54 PM
marines's Avatar
marines
Thank you all. Here in Alabama I drive it all year long. Thank all of you for answering this and putting my mind to rest. I do love my C4. Again, thanks.
To Battery Tender Again
