coolant temp problems
Old Dec 11, 2019 | 09:47 PM
slim56's Avatar
slim56
3rd Gear
Default coolant temp problems
what would cause the coolant temp go up to max temp when you accelerate and come back down when you let off accelerator. does anybody know or has anyone had this problem before.
Old Dec 11, 2019 | 10:40 PM
CorvetteRules's Avatar
CorvetteRules
Check hoses to see if at higher rpm hose isn't restricting and cutting coolant flow.
Old Dec 11, 2019 | 10:52 PM
s carter's Avatar
s carter
Any time you have a temperature problem go though the Basics, is it good coolant topped off and at a proper mix too weak (watery)a running car at Highway speed can freeze Radiator in cold enough areas.
The front of Radiator is it clear of debris this includes the gap between AC & Radiator and of course the Thermostat isn't stuck.
Old Dec 12, 2019 | 07:25 AM
slim56's Avatar
slim56
3rd Gear
vehicle isn't overheating has new coolant and all aluminum radiator no a/c condenser at this time new thermostat 195 degree. I think it might be electrical but don't know where to start looking
To coolant temp problems
