1992 headliner issue
Old Jan 17, 2020 | 09:49 AM
carlbobb's Avatar
carlbobb
3rd Gear
Default 1992 headliner issue
Headliner in my 1992 Corvette has come loose ans is sagging quite a bit. How much trouble is it to replace?
Old Jan 17, 2020 | 09:51 AM
PoloGreen92's Avatar
PoloGreen92
Are you talking about the black fuzzy stuff on the targa?
Old Jan 17, 2020 | 09:55 AM
carlbobb's Avatar
carlbobb
3rd Gear
Yes
Old Jan 17, 2020 | 10:04 AM
PoloGreen92
I'm pretty sure it's just glued on or held in with pins or something. They sell replacement ones. I can't imagine it being too hard especially if you pop the top off and get it on a bench or some sawhorses. I replaced the weatherstrip channels and rubber on my top a couple months back. Might be a good time to replace all that stuff too if you're messing with it.
Old Jan 17, 2020 | 10:21 AM
Whaleman's Avatar
Whaleman
The worst part for me was scrapping off the old glue.
Old Jan 17, 2020 | 12:35 PM
FAUEE's Avatar
FAUEE
Just make sure you get the correct headliner glue. It's surprisingly expensive at auto parts stores, but anything else will not hold up. Ask me how I know...
Old Jan 18, 2020 | 12:00 PM
marines's Avatar
marines
What glue did you use? Thanks.
Mike
Old Jan 19, 2020 | 11:01 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
PM sent
Old Jan 19, 2020 | 12:20 PM
FAUEE's Avatar
FAUEE
Mike
I have had ok luck with 3m super 77. The right stuff is labeled as specific heainer adhesive, 38808 or something like that. I am going to try permatex headliner adhesive when I redo my mini headliner.
Old Jan 23, 2020 | 09:08 PM
92C4Vette's Avatar
92C4Vette
https://www.corvetteforum.com/forums...cking-pad.html
This thread has some good info. I did a simple and cheap repair on mine few months back, still looks like brand new.
Old Jan 23, 2020 | 09:58 PM
RetroGuy's Avatar
RetroGuy
Here's another headliner option to consider. I performed this technique instead of using all that adhesive to try and fix my droopy headliner: Remove the roof panel and flip upside down on a padded scratch-free surface. Get a small dry wall putty knife/spatula blade. Use the blade to "tuck" the loose headliner fabric back into/under the seams around the borders and make it taught all around. Once it's all taught the way you like it, you can apply a bead of matching silicone sealer around the entire tucked-in fabric. Mine was black, so I used black silicone. Now, the fabric will not be adhered to the interior of the roof panel with this technique, but it will appear to be even though it's stretched tight with approx a 1/2" or so gap between the fabric and roof panel. It even works while driving with both windows down, not flapping with incoming wind. I'm 6ft tall and my head still doesn't touch the headliner fabric after this repair.
Old Jan 24, 2020 | 05:18 AM
kenmohr's Avatar
kenmohr
Mine was loose 9 years ago. went to a local shop to question what glue. The tech said the glue must be a certain glue or it would not hold. I wrote it down and as I was leaving I asked what tey would charge to fix it. Trying to see how much I would save. He said $70.00. Took the top off and left it there. No regrets.
To 1992 headliner issue
