How do I fix window/window fuselocation
Old Jun 20, 2020 | 03:22 AM
Sinisterturtle's Avatar
Sinisterturtle
7th Gear
Default How do I fix window/window fuse location
The driver side door on my 87 corvette doesn’t work and I wanted to know where is the fuse because when I hit the switch nothing makes a noise so I want to start with the fuse
Old Jun 20, 2020 | 07:39 AM
C409's Avatar
C409
….. Power window circuit breaker is in the fuse panel on the right side of the dash … open the passenger door to see it … your issue is most likely the motor … mine just did the same thing and l got lucky 'cause on mine it was just filthy contacts where the harness snaps on to the window motor … cleaned 'em up and jiggled the regulator and it started working again …..
