Is there a fuel alert when it gets too low?
#41
Adversely. You could post a video and poke a hole in your tire to prove that air comes out of the whole tire and not just the bottom!
Just so we’re clear here...This is a Pro-Tommy post for those of you with poor reading and comprehension skills.
#42
So some say. Note that fuel is running THROUGH the pump regardless of level and that should cool it fine.
Does the pump even need "cooling"? IDK. I did this test a few years ago....
Well...now I can't find it. I posted a video years back where I ran a fuel pump completely dry, for something like 30 minutes? It didn't overheat OR die. Then I dropped it in gas and it pumped like a son of a bee. So....I used to be a total believer in low or no gas = hard on pumps....but now I'm pretty skeptical of the "overheating" claim.
EDIT: Found it!
https://youtu.be/A6Y7aBAxe5o
EDIT: Found it!
Your objective experiment reminds me of a room full of "experts" at the Columbia Space Shuttle disaster hearing regarding the seals on the (Morton Thoicol) shuttle boosters.
The sometimes heated arguments surrounding the specifications for the seals and whether or not they would have performed (remained elastic, i.e., functional) at the freezing temperatures went on back and forth in the conference room for over an hour.
Meanwhile, (and I forget his name now) one of the scientists was sitting quietly stirring his glass of ice water with a sample piece of the failed gasket seal material in it. And, after a few minutes he tested the seal material's ability to rebound at 32ºF (approx temp at the launch) by pressing his thumbnail into the gasket material.
Guess what? The dent his thumbnail left in the gasket material DID NOT rebound, contrary to "specifications" being argued and argued. And, when he got the attention of the room, he enlightened the group with his findings. The seals fail at freezing temps. End of meeting!!
I too like your fuel pump test! Yeah, I know, I know..., "One test does not a trend make!", but it sure as heck opens a window in the oft touted failure 'if ever the pump runs dry' argument!! So often a limited or very narrow test result gets repeated and expanded around and next thing you know, BS is created!
Good point, my friend!! Thanks for sharing.
#43
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
So the moral of this story is if want keep waiting on a warning to tell you low on fuel at some point you will run out and be walking Its a gauge just like all the others in your car to warn you of impending disaster, just fill it up when its low.
#44
Not if you have a smart car and it runs out on top of a hill!
#48
Pro Mechanic
When the last/lowest bar extinguishes, so there are NO bars, the "Check Gauges" light comes on.
