Is there a fuel alert when it gets too low?
on my 96 is there supposed to be a light or an alert chime when the fuel gets too low? That would be a nice feature.
It says "reserve"... cant remember if thats 1 bar or 2 bars.
FAUEE (07-04-2020)
Tom400CFI (07-13-2020)
The following 12 users liked this post by WarlockIII:
'78CorvetteS.A. (07-17-2020),
81c3 (07-15-2020),
Bugly87 (07-04-2020),
convas (07-04-2020),
GRIS (07-04-2020),
and 7 others liked this post.
When RESERVE pops up, fill it. Just because the digital displays 35 miles left till empty doesn't mean you can go 5 miles to the gas station. How do I know?????
The following 2 users liked this post by Charsel:
Gunho (07-15-2020),
Paul Workman (07-16-2020)
Received 7,028 Likes
2015 C2 of Year Finalist
do you have a owners manual ?
Carry your own reserve like this guy...
WarlockIII (07-04-2020)
There is no chime, but you'll get three warnings.
Warning #1: The "RESERVE" indicator will come on, indicating you're now below 25% fuel.
Warning #2: Hard acceleration will cause the car to buck as fuel sloshes away from the pump pickup.
Warning #3: The fuel range indicator will change from a number to "LO" and the "CHECK GAUGES" light will illuminate, indicating you are about to run out of fuel.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Once the last two bars disappear the dash warning light "CHECK GAUGES" lights up. I think that is a 95 & 96 only feature. I know my 92 didn't have it.
The first and only time I saw the reserve message was when I found out my sending unit was sticking.
I was driving home with a 3/4 tank reading when I cross a railroad track. Suddenly the indicator goes to 2 bars and reserve shows up.
Got home and when I pulled the sending unit I could feel a bind in the arm. Guess it got stuck and the tracks jarred it loose. I replaced the sending unit but now kind off watch the trip odometer as well.
The following 2 users liked this post by coupeguy2001:
Hot Rod Roy (07-11-2020),
vader86 (07-14-2020)
