1994 Corvette High Idle Problem
Old Jul 4, 2020 | 06:01 PM
Bowtie Boss's Avatar
Bowtie Boss
2nd Gear
Default 1994 Corvette High Idle Problem
After changing the opti, water pump, spark plugs, wires, ignition coil, and ignition control module, car idles high and seems to not want to shift out of 1st gear. Also...when I put it into gear, it's as if somebody slammed on the gas. Anybody heard of this problem???
Old Jul 4, 2020 | 07:01 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
is the check engine light on? if so fix that first
Old Jul 4, 2020 | 10:14 PM
Bowtie Boss
2nd Gear
Yeah the check engine light was on. Had codes of H15, H42, & H64. Cleared the codes and check engine light came back on. Now when I give it some pedal, it acts like it loses power then takes off
Old Jul 6, 2020 | 08:34 AM
FAUEE's Avatar
FAUEE
Did you put the opti on right? Didn't jam it in and screw up timing?
To 1994 Corvette High Idle Problem
