AC compressor won’t engage
Old Jul 8, 2020 | 02:41 PM
Admiralvette's Avatar
Admiralvette
2nd Gear
Default AC compressor won’t engage
Hello, I have a 88 vette with c68 option, just installed a new ac compressor, have the constant 12v at the compressor system won’t engage from inside the cabin. When I manually ground the compressor it works and cools properly (pressures look good). I was talking with batee corvette and apparently you can no longer get the blower motor resistor that triggers your ground for the ac, I have a new standard brand that I had installed, so I reinstalled my original one and the ac worked, but only for a few cycles, so has anyone heard this being a problem and is there any good solutions other than a used part from a yard?
Old Jul 8, 2020 | 03:33 PM
WarlockIII's Avatar
WarlockIII
Are you trying to turn on the A/C with no refrigerant in the system? If it’s low or empty it won’t engage.
Old Jul 8, 2020 | 05:00 PM
Admiralvette
2nd Gear
Pressure is good system full, have 6 volts coming from the head unit in the car, both high and low pressure sensors have continuity and 5-6volts running through them, the blower motor resistor isn’t switching the ground for the compressor, has anyone heard that you can no longer get this part? It was explained to me that the 90 and up system the resistor looks the same but the 90 engages the compressor a different way than the 86-89
Old Jul 8, 2020 | 07:39 PM
Kevova's Avatar
Kevova
Blower control module is available GM 16061602 it was also used by Buick. Cadillac, & Oldsmobile in late 80's on high line models if shopping for used.
Old Jul 8, 2020 | 07:48 PM
RWDsmoke's Avatar
RWDsmoke
This is the one I have from Amazon for my 86.
Amazon Amazon
To AC compressor won’t engage
