94 Corvette body control module
Old Aug 17, 2020 | 10:46 PM
dc6902's Avatar
dc6902
Default 94 Corvette body control module
Anyone know of someone who sells and programs body control module for 94 Corvette in Houston Tx area?
Old Aug 18, 2020 | 07:48 AM
corvette95's Avatar
corvette95
You won't find anyone. You can send off to a company along with your car's info and they can rebuild it, Why do you need to replaced a control module, that's a commonly replaced piece that turns out usually to be something else. This is who I use https://corvettesalvage.com/
Old Aug 18, 2020 | 10:46 AM
dc6902's Avatar
dc6902
I've reduced it to this because of intermittent no starts, inoperable windows,radio. I can start and run car, cut it off, attempt to restart and nothing happens. I wait a few minutes and it starts. Sometimes it won't start first thing in morning.
Old Aug 18, 2020 | 11:12 AM
corvette95's Avatar
corvette95
Are you able to read ECM AND CCM codes? Looking for a CCM code 41. Will the ECM flash 12?
Old Aug 18, 2020 | 03:44 PM
dc6902's Avatar
dc6902
I only got a code 33
Old Aug 18, 2020 | 03:46 PM
dc6902's Avatar
dc6902
Tested with scan tool on obd2 even though car has obd1 system
Old Aug 18, 2020 | 03:52 PM
corvette95's Avatar
corvette95
You need To access CCM. You can through a paper clip in the ALDL.
Old Aug 18, 2020 | 05:05 PM
dc6902's Avatar
dc6902
I will retest according to you alls replies
Old Aug 18, 2020 | 09:11 PM
dc6902's Avatar
dc6902
I shortened from pin 4 to pin 12 on connector.
The following came up on the digital dash.
1. H 51
1. H 72
4 H 16
5. H 33
I did have wiring separated on passenger side while replacing heater core last week. Some of this may be caused by that,however, the start began long before then and continues now.
Perhaps it is the switch on the column as am not always getting voltage from the yellow lead.
I will have to address windows and radio later plus engine vacuum.
To 94 Corvette body control module
