Overheating problem
Old Sep 21, 2020 | 10:52 PM
Alexh4505's Avatar
Alexh4505
Cruising
Default Overheating problem
My 1990 corvette has been overheating, coolant just slowly climbs up and over past operating temperature, never let it get to the boiling point though, any suggestions? I’m not sure if it’s correlated but the oil temperature seems to go up incredibly slowly as well. My first step will be flushing the coolant as well as changing the thermostat, not sure if it’ll fix the problem, but we will see.
Old Sep 21, 2020 | 11:08 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
what temp?
Old Sep 21, 2020 | 11:57 PM
Alexh4505's Avatar
Alexh4505
Cruising
It never stops, but by either coasting without accelerating or pulling off and letting it cool, I've never let it reach 260 degrees. Definitely could reach it and it has been incredibly close to before.
Old Sep 22, 2020 | 01:17 AM
Ronn38's Avatar
Ronn38
I’d start by making sure your fans are coming on — should hear them/get a drop in volts at about 215. Next, make sure there’s no junk between the radiator and the AC condenser. Is your overflow tank full, or are you losing coolant? I’d flush the system after checking on those things.
Hope that helps,
Ronn
Old Sep 22, 2020 | 08:10 AM
Cruisinfanatic
Yes, check to make sure you fans come on.
Then you need to get your radiator out of the car for cleaning. That and a new thermostat will likely fix the problem.
It could look like this and it can't be cleaned thoroughly without removing
Old Sep 22, 2020 | 03:26 PM
don hall's Avatar
don hall
Cooling is quite basic. Air flow and coolant flow. Stop one, or both, and the temps will rise.
Heed the suggestions for fan operation, and a clear path for air flow through the radiator..
A t-stat not opening fully will cause high temps.
Insufficient coolant with cause high temps.
A faulty water pump will cause high temps.
Include with the coolant flush remove/replace the knock sensor(s).
Check the coolant reservoir cap gasket for distortion. Replace, if necessary.
A head gasket breach allowing exhaust gases into the cooling system will cause a rapid rise in temp.
Cooling has been a popular subject since day-one. There are probably a thousand posts on cooling.
Spend some time researching old threads. It will be a tedious project, but you will learn how to use
the search feature for future concerns.
Good luck with your vette.
Old Sep 22, 2020 | 06:26 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Owning my C4 for less than 3 months, they seem to run uncomfortably warm. I get nervous when I see it climb pass 220*F but been told that is normal. Run through items as suggested @ 260*F I would be having a panic attack!!!
Old Sep 22, 2020 | 08:36 PM
Alexh4505's Avatar
Alexh4505
Cruising
Thank you very much for the advice! I did a full flush of the coolant and changed the thermostat, seemed to work it all out, I will keep your advice in mind if later issues come up. Thank you!
Old Sep 22, 2020 | 08:39 PM
Alexh4505's Avatar
Alexh4505
Cruising
I kept your advice in mind while I changed the coolant, which was a disgusting dark shade of green, as well as the old thermostat. I was able to peek in through the shrouds on each side and the radiator looked very clean, and I made sure the fans worked. Now the temp stays exactly where it should, 160~ at idle, 220~ when moving. Seems like the coolant wasn’t changed for quite some time. Thank you for your advice!
To Overheating problem
