Of course not to drive, but to store to reduce flat spotting. Why not?
What tire manufacturer says not to do it for this reason?
whatever the max pressure on the tire is... don't go past that. Mine are 51. Mine also don't flat spot bad when properly inflated... I drive the 1/4 mile to the end of my street and its gone...
Why not? Because you could damage the tire and/or create a safety issue. Why do YOU think the tire manufacturer puts a max pressure warning on the tire?
I haven't poled tire manufactures about why they say not to do it....for a ritual that ain't worth doing. I simply....don't do the ritual.
*Fill the tank
*Change the oil (if it's not a recent change)
*Manage the battery.
*Retrieve it in the spring for fun summer driving.
Most folks recommend filling the tank and adding a stabilizer, Why not just empty the tank and make sure the cap is on tight? Isn't it a closed, nonvented system?
With a full tank, you've displaces all of the air, so as temps change, you don't get condensation happening inside the gas tank. The alternative would be to drain it dry, then feed it positive ventilation all winter (through in/out hoses?) but that would be yet another "ritual" that is a total waste of time and effort.
Fill the tank. KISS.
Honestly the condensation thing is bs too. The 55 has had the same hlaf tank in it for a year and a half now and there is not a drop of water in that tank and I plan on burning it off come April when the motor is finished. It does have lead additive which also has stabilizer in it though. Non hardened seats back then.
You're probably right. At work, our vehicles get parked at the end of their repective seasons, with "whatever" amount of fuel in them; whatever amount that the department who uses them, had in them when they parked 'em.
Over 25 years I've been working with these fleets and not yet have we had a fuel issue caused by condensation. Or:
*gas going bad
*tires getting flat spots/carpet squares/storing vehicles on stands.....
*water coming up through the floor and rusting vehicles
*etc. etc. etc. etc.......
We park the trucks, 4-wheelers and side by sides in the fall...they sit all winter, run fine in the spring.
We park the snow cats, snowmobiles and busses in the spring and they sit all summer, run fine in the fall.
