Cold air induction ???
Old Dec 5, 2002 | 03:37 PM
vargod's Avatar
vargod
Default Cold air induction ???
This will be going on a 96 CE LT4. Has anyone on this board ever used or knows some who has used this cold air induction system by SLP. Before I traded my SS I used their stuff all the time, but I don't know how they are with vettes.
Old Dec 5, 2002 | 06:55 PM
NightRyder's Avatar
NightRyder
Default Re: Cold air induction ??? (vargod)
i was under the impression that cold air doesnt help vetts, (not enough to be worth it maybe?)... can some one clarify? i might be wrong... :confused:
... the more i think about it the more im not sure anymore.. :)
Old Dec 5, 2002 | 07:01 PM
vargod's Avatar
vargod
SLP is stating a 20-25 HP increase. I know on the SSs with the LS1, they were usaully on the $$.
Old Dec 5, 2002 | 07:09 PM
GDP's Avatar
GDP
I wouldn't buy that claw one. What it seems to me like it really is, is just a way to remove a bunch of the restriction from the air lid, as opposed to real cold air. Of course, I don't know for sure, I've never done research on it. Another thing, I think it's rather ugly-looking. If you want an improvement, and I'm not saying it's better, because I don't have any experience with it--just seems like it would work better, is the ram air kit that installs in the front license plate area. IMO it's just as ugly as the cold air intake kit you're asking about, but it seems like it would be more effective. Another ram air kit on the market uses a hole cut in the radiator shroud to pull air up from underneath the car.
[Modified by GDP, 6:09 PM 12/5/2002]
Old Dec 5, 2002 | 07:43 PM
LT4BUD's Avatar
LT4BUD
Don't believe the 20-25 Hp!! Not true for an LT4. It is a great looking system & easy to install. I have it on my LT4. Many others have this system and like it, but no one has ever said they acheived this kind of power gain.
Old Dec 5, 2002 | 08:34 PM
vargod's Avatar
vargod
Default Re: Cold air induction ??? (LT4BUD)
LT4BUD
Do you have a pic of what it looks like installed?
Old Dec 5, 2002 | 11:04 PM
GDP's Avatar
GDP
Check out this thread, especially what vader has to say about the three cone intake. It confirms my suspicions that it isn't a real cold air intake. http://forums.corvetteforum.com/zerothread?id=446254
Old Dec 5, 2002 | 11:11 PM
vader86's Avatar
vader86
Default Re: Cold air induction ??? (GDP)
the CLAW 3 cone thing doesnt help that much really, and then only above 80mph where the slightly increased flow might help trap speed. Its not even a cold/ram air setup, although a REAL cold air setup will help vettes, our engines work on the same principles as any others do. cold intake air=hp
I dont recall of anyone who has gained any significant ET from it. It certainly doesnt provide 20+hp, and is only slightly better than the cut lid w/ K&N.
You want my opinion, dont buy this one, save your money for a more worthwhile mod.
Old Dec 5, 2002 | 11:56 PM
The Dingo's Avatar
The Dingo
CI 6-7-8-9-10 Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-‘17, '22
Default Re: Cold air induction ??? (vader86)
The setup you have pictured still draws air from the same area of the engine compartment as the stock filter so I'm at a loss as to why it would be called a cold air intake. To qualify as a cold air intake in my opinion you either need one of the two available kits that draws air from the underside of the radiator shroud or a forced air intake.
IMO for the money asked I would skip on the intake pictured and either go for a K&N and cut lid (lowest cost) or a true cold air intake.
Old Dec 6, 2002 | 07:18 PM
Marlin in Minn's Avatar
Marlin in Minn
I've got an SLP Claw on my Vette and I love the way it looks. As a matter of fact, the way it looks was the only reason I bought it.
The Claw flows up to 1500 CFM, which is the same as the factory air cleaner with a cut lid and quality filter.
I've got a couple of pics of it installed that I can email to you if you'd like to see them.
Old Dec 6, 2002 | 08:18 PM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Cold air induction ??? (Marlin in Minn)
:yesnod: Exactly! I've gotten more than a few compliments with it on. It also gives you more of a "throaty" sound at WOT...sort of like a 4bbl without the airfilter. :D
Old Dec 6, 2002 | 08:42 PM
vargod's Avatar
vargod
Yeah, please I'd like to see what they look like installed b4 I buy them.
vargod@earthlink.net
Thanks Doug
[Modified by vargod, 1:56 AM 12/7/2002]
Old Dec 6, 2002 | 09:26 PM
vader86's Avatar
vader86
It is true that they make a different sound than the stock setup, kind of a whistle or whoooosh if you were standing in front of the car.
And the couple ive seen it on do look cool.
Old Dec 6, 2002 | 09:34 PM
kittmaster's Avatar
kittmaster
I run a vortex air rammer.....only down side is you must cut the radiator shroud....by no means difficult but a decision that can't be undone easily. I jumped on board. The transient response of the car was improved, but 20 HP :bs ....hmm...10 maybe ....anything over that stock POS is better....no doubt :thumbs:
Old Dec 8, 2002 | 04:07 PM
Marlin in Minn
I couldn't hear or feel any difference when my car was stock, it just looked good. Now with the stoker engine, you can definitely hear it sucking air. :yesnod:
Old Dec 9, 2002 | 04:33 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
I've got the SLP intake on my '94 -- had it for 2 years now. It doesn't really give any performance increase, but it sure does look good :jester ! That is the primary reason I bought it. I did not want to cut the radiator shroud for the BPP Vortex.
Old Dec 9, 2002 | 06:12 PM
pwrful c4's Avatar
pwrful c4
Iuse the Vortex Ram Air,it gave me a few more ponies and works well :seeya
To Cold air induction ???
