As you can see in the below picture. I was replacing the hoses and the nipple on the tank came loose. That’s what I get for doing preventative maintain effective😩
My question is how to repair this so I do not have to worry about it, I was thinking of epoxy or soldering?
trying not to make a bigger problem.
Robin
The term "brazing" comes to mind... a competent plumber might be able to bond those together properly. Would have to be careful of the plastic though.
I am not a plumber so my head might be up my **** on this one.
Thanks guys for all the help.
I tried to solder it. It did not work. I ended up using JB weld. Time will tell if it holds. If not I will buy a new one.
thanks again,
Robin
