Code 22, 89 Conv
Old Nov 23, 2020 | 02:55 PM
shafe9900's Avatar
shafe9900
Advanced<br><img src="/forums/images/ranks/100-500.gif" border="0">
2023 Corvette of the Year Finalist - Unmodified
2022 C4 of the Year Winner - Unmodified
Default Code 22, 89 Conv
Receivedthe code 22 and replaced the TPS on my 89. Set the voltage at .54 and ran fine for a couple of weeks. Him getting cold 22 again, then attempted to reset the voltage and got no voltage at all. I looked in the shop manual and told me to jump all 3 connections on the TPS. When I did, I got a negative voltage reading. Any ideas or help would be greatly appreciated. Thank you forum!
Old Nov 24, 2020 | 09:39 AM
jazfe's Avatar
jazfe
If you are getting a negative reading just swap the multimeter leads.
Old Nov 25, 2020 | 12:46 PM
shafe9900's Avatar
shafe9900
Default No reading
Thanks for the reply. I did that and got no reading at all.
I'll try another TPS.
Old Nov 25, 2020 | 08:21 PM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
This is a '87 schematic and I'm purdy sure nothing has changed in '89. To me it sounds like a wiring issue. Check for volts and continuity of the wires to the ecm.
Old Nov 26, 2020 | 03:59 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Test the two outer wires and you should see +5Vdc, if a negative value reverse DMM leads.
Then, keeping the DMM ground lead on the ground side of the TPS, measure the center electrode voltage.
Also, pull the TPS connector and inspect/clean the connector pins for solidarity. They should be clean and not move in/out when pressed lightly.
Old Nov 26, 2020 | 01:59 PM
shafe9900's Avatar
shafe9900
Default Thanks.
Thank you for the advice! I will check it out. Appreciated the diagram as well.
Old Nov 27, 2020 | 04:31 PM
shafe9900's Avatar
shafe9900
Default Code 22
Now I'm setting the TPS and I can't get a reading above .31 V
This is beginning to drive me nuts. I did replace my idle air control valve about a month ago.
Suggestions would be greatly appreciated.
Thank you guys out on the forum!
Old Nov 29, 2020 | 04:43 AM
stew86MCSS396
Did you set minimum air idle when you change the IAC?
https://www.corvetteforum.com/forums...dle-speed.html
Old Nov 29, 2020 | 02:47 PM
shafe9900's Avatar
shafe9900
Default 89 Vette
Yes I did..thanks.
To Code 22, 89 Conv
