Bose Gold stereo system?
Old Jan 4, 2021 | 06:42 AM
DominusRex's Avatar
DominusRex
Default Bose Gold stereo system?
When I bought my 90 coupe, the stock head unit in the dash had been removed as the owner said it was causing a short or something when it was installed. I'll investigate this and get more info later on.
My question is, can I install a new, aftermarket head unit with a wiring harness adapter and have it work with the stock speakers and amp(s)?
Or, if I want/need a new head unit, must I replace all the components of the stock system?
I've been told that both are true by many people so I'm hoping I can get a straight answer here.
Also, is there a way to test if this head unit works without installing it in the car? And, if it is working, is there any possible way to add a Bluetooth function to the stock system? If this head unit works and I can resolve the electrical issue mentioned in the beginning, I'd like to keep the stock system but it won't be of much use if a Bluetooth receiver modification isn't possible. I'm fresh out of tape decks 😂
Old Jan 5, 2021 | 09:21 AM
miles71's Avatar
miles71
Cheap Bluetooth / Bose option:
If you can get the Original Head to work.
If your existing Bose speakers/amplifiers still work.
If your Cassette deck is still working.
You can buy a Bluetooth Cassette option.
The Battery power Bluetooth cassette will plug in to the deck and sync with your phone
and then you will be able to play music on your iPhone into the Bose radio.
On my Bose system, I used a cheaper solution, I used a Cabled version of the cassette adapter.
I plug in the stereo cable into the bottom of my iPhone 10 and listen to music on the Bose.
Note: I had to buy a stereo to iPhone adapter cable for 10 bucks.
The MP3 Music through the cassette adapter to the Bose actually sounds much better than the stock Bose FM.
Miles71
Old Jan 5, 2021 | 10:10 AM
jrobin1's Avatar
jrobin1
Not sure about the bluetooth mod, but you can have the control unit modified to add an auxiliary in port. That will allow you to play your music from your phone/device through the car system. My experience with the cassette option was unsatisfactory. It had a lot of head noise.
Corvette Bose Gold Car Stereo and Amp Repair and Removal (carstereohelp.com)
To Bose Gold stereo system?
