Smog Pump Delete
Old Jan 5, 2021 | 01:02 AM
WillC41990's Avatar
WillC41990
Default Smog Pump Delete
So back in September or so my smog pump went out and I replaced it with an idler pulley. (On a side note, I highly recommend the CNC machined smog pump delete kit from tandthorsepower on eBay. Very high quality with very good instructions. Fair price too.) All the emissions junk just clutters the engine bay and I’ve been wanting to remove it for months now. Can anyone that’s done this mod tell me what I can start pulling out to clean up the engine bay? Are there any electrical systems I have to trick to avoid ses lights? Any information would be greatly appreciated! Thanks!
Old Jan 7, 2021 | 01:09 AM
aklim's Avatar
aklim
Remove the check valves where the thin metal pipes go into the exhaust manifold. Cap them. Follow it and you will get to the AIR diverter valves. Take that off. Somehow prevent the wires from getting wet. Part of the AIR system is the metal hose that goes to the cat. Cut that off and seal it at the cat. Remove the metal line.
Old Jan 7, 2021 | 11:47 AM
WillC41990's Avatar
WillC41990
If I am looking at this correctly, the cat line has a check valve. Can I leave this valve on instead of sealing the cat? I don’t know if I can weld to the line to seal it. Is there another option to seal the cat? Thanks!
Old Jan 7, 2021 | 11:51 AM
WillC41990's Avatar
WillC41990
Also do you have any suggestions for removing the line that goes across the engine between the A/C compressor and the engine head? I can’t seem to find a way to wiggle it out of there.
Old Jan 7, 2021 | 08:27 PM
aklim's Avatar
aklim
I would think it could suck air into it but that shouldn't matter. In an aftermarket cat, they supply a plug which is just a piece of metal blocking the tube so it isn't too difficult
Old Jan 7, 2021 | 08:29 PM
WillC41990's Avatar
WillC41990
Thanks! I’ll plug that tube up
Old Apr 17, 2021 | 10:44 PM
InfomanSS's Avatar
InfomanSS
I highly recommend the CNC machined smog pump delete kit from tandthorsepower on eBay. Very high quality with very good instructions. Fair price too...
I can't find an item like this on their eBay store...happen to have any more info? Perhaps it is no longer offered?
Old Apr 18, 2021 | 07:39 PM
aklim's Avatar
aklim
https://www.corvettemods.com/C4-Corv...MaAonsEALw_wcB
Old Apr 18, 2021 | 08:22 PM
TommyFox's Avatar
TommyFox
I grew weary of trying to get it out and cut it. Also used JB weld to seal the air hole but mine did not have a center cat. Its all gone now, cats all deleted with some cheap Hedman Headers. I dumped all the emissions, egr block off etc and had it all deleted in my PROM program. Runs much better...
Old Apr 18, 2021 | 09:31 PM
InfomanSS's Avatar
InfomanSS
I messaged the seller, more are being made now and will be on their store when complete.
Old Apr 19, 2021 | 09:55 AM
28uniflite's Avatar
28uniflite
It's very easy to "gut" the factory air pump. I did an emissions delete last year consisting of removing egr, air pump, cats, and proper reprogramming. Rather than go with an idler pully, I opted to gut my factory air pump. I took it apart, pulled all the vanes and mechanism out of it, and greased the bearings. I also removed all air lines and check valves. My old air pump now functions perfectly as an idler pully.
Old Apr 19, 2021 | 09:58 AM
aklim's Avatar
aklim
Much easier and takes less space to use a pulley but if you have to do emissions, definitely gut it.
Old Apr 19, 2021 | 01:00 PM
76C3forme's Avatar
76C3forme
I'd be extremely cautious about purchasing anything from Corvettemods.com
Old Apr 19, 2021 | 02:07 PM
aklim's Avatar
aklim
https://www.zip-corvette.com/85-91-a...8aAgwzEALw_wcB
Not sure why there is a difference but corvette mods came out first with the search. What again is the issue with them?
Old Apr 20, 2021 | 08:21 AM
76C3forme's Avatar
76C3forme
..... Only one the worst corvette vendors of recent times, that's all (Corvettemods). A quick forum search should bring up quite a number of the negative posts as well. Google searches also bring up pretty much what everyone has experienced with this "company"..
But hey, Other than poor customer service, damaged items, no contact after the sale if there is an issue, lack of communication, slow shipping etc, they're top notch...... Even their employees post negative reviews about them...
Read some of their most recent glowing reviews at the bottom of this page:
https://www.sitejabber.com/reviews/corvettemods.com
Old Aug 31, 2025 | 11:11 PM
brownedpants's Avatar
brownedpants
4th Gear
Anyone know if that seller is around or of a very high quality one? Or even an actual high quality smog pump. Just want to get my car moving again and been going through pumps.
Old Aug 31, 2025 | 11:32 PM
WillC41990's Avatar
WillC41990
I don’t think they’re still around, but you’d probably be fine with any kit out there (I saw some for about $50 when I searched L98 smog pump delete). The biggest issue I ran into was the hardware I got with my kit, all the bolts broke off in the block. I think they were grade 5 from the kit, went to the hardware and got some grade 8 and never had any issues after that.
To Smog Pump Delete
Old Sep 6, 2025 | 09:35 PM
brownedpants
4th Gear
Would it cause any harm to just cap the rubber hose coming from the air pump, after removing the air pump and putting an pulley on? I wasn't sure if any hot air would come back and melt anything or cause the engine to run poorly.
Old Sep 6, 2025 | 09:59 PM
WillC41990's Avatar
WillC41990
I would cap off the manifold with some pipe fittings and just pull all the hoses out. It will cause you less headache and it helps clean up the engine bay at the same time.
I can’t remember exactly the diagram of the system, but I’m pretty sure the gasses come from the manifold and go through the pump into the intake. If you plug that hose I could see it getting too hot.
Old Sep 7, 2025 | 09:16 PM
brownedpants
4th Gear
Thanks I might have to do that. I got into a tough situation where I was hoping this would have waited another two months but the smog pump gave out and I wanted to drive the car a little more before winter. Shouldn't take too long and then I can work on removing the other components slowly over the winter.
