Alarm System
Old Feb 3, 2021 | 08:46 AM
BillDurant's Avatar
BillDurant
Default Alarm System
how do I disconnect the alarm system in my 89 ? without causing other issues
Old Feb 4, 2021 | 08:28 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Are you talking of dis-arming your VATS system, or does the car aftermarket alarm system.
I believe VATS, you can't, and if you aftermarket system, either find the module for the alarm follow the wires, and discount them, or take it alarm place tell them to remove it.
Old Feb 4, 2021 | 09:22 AM
BillDurant's Avatar
BillDurant
It's the factory system
Old Feb 4, 2021 | 09:51 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
What is it doing you want it removed, and really you can't disarm it, can by-pass the ignitions system if it's malfunctioning?
Old Feb 4, 2021 | 09:52 AM
BillDurant's Avatar
BillDurant
Just to keep it from draining the battery
Old Feb 4, 2021 | 10:09 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
I never had drain on a battery on my 1989 I had four 23 years, never experience a drain, and if you have one I would recommend find the short in your electrical system or buy quick discount for your battery.
Amazon Amazon
Old Feb 4, 2021 | 05:01 PM
arbee's Avatar
arbee
If you want to read any current draw, you need to put your meter in series, not parallel.
Old Feb 4, 2021 | 05:02 PM
WVZR-1's Avatar
WVZR-1
For location of TDC (Theft Deterrent Controller) see 8A-201-8 (B) in the FSM. PASS KEY DECODER MODULE 8A-201-7 (C)
Old Feb 5, 2021 | 12:31 PM
jd4010's Avatar
jd4010
Cruising
I agree with @arbee . Need a meter to determine parasitic draw and then start isolating the issue. I've seen before where an alternator created the draw down despite it charging well.
To Alarm System
