'88 door panels
Old Feb 13, 2021 | 10:02 AM
pkrbkr13's Avatar
pkrbkr13
Default '88 door panels
I replaced the door panels on my C4, and the rubber wipers don't come close for a good fit. Any suggestions as to how to tighten the areas?
Old Feb 16, 2021 | 09:05 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Rubber wipers? Do you mean the long rubber trim between top of panel and the glass?
Can you provide a pic?
Old Feb 16, 2021 | 02:46 PM
pkrbkr13's Avatar
pkrbkr13
Yes, they are the rubber wipers. I tried taking a pics, but it like 5* out and dark in my garage. Will try this weekend with a trouble light. There is
a gap about 1" about on center of the strips. I have the windows down, and the battery disconnected. The inside ones don't even touch the glass.
Thanks for responding.
Old Feb 17, 2021 | 05:30 AM
65Z01's Avatar
65Z01
Is the top lip of the door panel firmly overlapping the metal door panel top?
I find that my old "referbed" door panels tend to slip up and off the metal door top which leaves them rather "flopping".
I have to press down on the upper door panel so that it doesn't "jump" up and off the metal as I slip the panel into place.
Old Feb 18, 2021 | 04:51 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I agree. You don't have the panel on right
To '88 door panels
