89 vette
Old Feb 19, 2021 | 05:55 PM
Michael J. Cripe's Avatar
Michael J. Cripe
1st Gear
Default 89 vette
How do you adjust the idle speed for an 89 Corvette? (Pics please)
Old Feb 19, 2021 | 11:22 PM
jv9999's Avatar
jv9999
You don't. The ECM (computer) adjusts it based on signals it's getting back from the sensors. A good place to start is to make sure your throttle position sensor is working and adjusted properly. This is a good how to. The adjustment is the same on all GM L98/TPI motors. https://www.iroczone.com/articles/en...on-sensor-tps/
Old Feb 20, 2021 | 10:08 AM
Dt86's Avatar
Dt86
If you have a high idle I would check for vacuum leaks. Brake booster, vacuum lines, plenum gaskets are good places to check.
To 89 vette
