Transparent targa issue
Old Mar 30, 2021 | 07:58 AM
jdcar32's Avatar
jdcar32
Default Transparent targa issue
I'd like to hear about your experience with polishing an OEM transparent targa roof. Mine has areas that you can't snag with a fingernail but you can see, marring and swirls. I don't want to make it worse, just see some improvement. Thanks
Old Mar 30, 2021 | 08:48 AM
FAUEE's Avatar
FAUEE
Plenty of people have done it. My main concern would be getting a protective coating back on top of it. I don't know that you could polish just a section of it either.
Relensing isn't that expensive though, so that's nice at least.
Old Mar 30, 2021 | 12:11 PM
car addict's Avatar
car addict
The thing I've seen most often recommended here is the liquid version of Barkeeper's Friend. Mine's so scratched I think I would have to remove too much acrylic so I haven't bothered to try. I just put 303 Aerospace protectant on the outside of mine, or maybe whatever quick detail I might be using on the rest of the car.
Old Mar 30, 2021 | 12:43 PM
Kmcoldcars's Avatar
Kmcoldcars
I did mine. I sanded with a very fine sandpaper, about 1500 as I recall, until all the old coating was off, since the scratches went through the coating. I then buffed it a couple of times. It still looks like new after about 4 years. I use Rejex on it when I do the car.
Old Mar 30, 2021 | 01:50 PM
colter's Avatar
colter
I have an OEM top that's all crazed. I've left it like that as I assume the protective coating that's on top helps protect the lexan from UV damage from the sun? Or just for scratch protection?
To Transparent targa issue
