Spare
Old Apr 25, 2021 | 06:19 PM
Beater12's Avatar
Beater12
Default Spare
Are replacement tires available for the space saving spare. I have a 90 and I wouldn't be surprised if its never been down.
Old Apr 25, 2021 | 06:42 PM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
I've been unsuccessful in finding anyone who has a direct fit replacement spare. This is a topic that has been discussed quite a bit and after reading countless threads I have yet to find anywhere where a member has found direct replacement replacement rubber. I've tried locating a replacement tire locally though all the tire shops I could find for my '86, and have come up empty handed.
Now there IS a company that makes a complete replacement spare tire kit for our cars, and here's the link ---> 1984-1996 Chevrolet Corvette Spare Tire Kit Options
This may be the only option to having a "new" spare reside in the rear tub. It's not cheap, but it solves the problem of good spare vs. questionable spare.
Old Apr 25, 2021 | 07:39 PM
Beater12's Avatar
Beater12
Sorry I must have missed that thread. Thanks for the info, it is all I need.
Old Apr 26, 2021 | 08:00 AM
don hall's Avatar
don hall
No need for a space-saving tire. The tire carrier will accommodate a regular size tire using the 2-position adjustment.
Old Apr 26, 2021 | 08:18 AM
Beater12's Avatar
Beater12
Yes I was made aware of that but have also read it lowers the carrier down so it is visible from the rear and may catch speed bumps etc.
Old Apr 26, 2021 | 11:16 AM
DGXR's Avatar
DGXR
Yes new replacement spare tires are available, for the later C4s anyway. In April 2017 I bought this from Tire Rack: T155/70R-17 CONTINENTAL CST 17
Not sure what size your stock spare is so maybe not applicable but thought I'd chime in here.
Old Apr 26, 2021 | 03:27 PM
Whaleman's Avatar
Whaleman
https://www.ebay.com/itm/333643685412 I bought this. Name brand. Date code showed it 9 months old. Dan
Old Apr 26, 2021 | 06:34 PM
73n95's Avatar
73n95
I don't b other with a spare. 4 cans of fix a flat and a charged cell phone. If I had a flat I couldn't get the stock jack under it anyway.
Old Apr 26, 2021 | 10:40 PM
DWAVette's Avatar
DWAVette
I can confirm Tire Rack sells a direct sized replacement for a ‘91. Not cheap, but available. It will mount on the rim and fit in the carrier.
My tire shop tried to find an as-close-as possible regular tire, but it was a little too wide to fit in the carrier in the highest position. So, I returned the tire and went with the space saver from Tire Rack.
I also keep a small battery air pump and plug kit/needle nose pliers in the car for typical nails, etc. The spare is for an unrepairable blow out.
Old Apr 30, 2021 | 09:49 AM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I'd read smewhere that Toyota had the same spare tire. Never looked into it, though.
I ditched my spare and threw a plug kit in the rear compartment anyway.
Old Apr 30, 2021 | 10:34 AM
John Armond's Avatar
John Armond
For my 96 I bought a used, but new production Subaru spare wheel complete with tire. I can’t remember which Subaru (Forester I believe) it was for, but the spare tires were the same size. Think it was about $65 total including shipping from eBay and $10 locally to have the tire pulled off the Subaru rim and put on my 96 spare rim.
Glad I got it too, because a few weeks later I picked up a nail and could actually hear the air rushing out while I was stopped at a light with the windows down.
Old Apr 30, 2021 | 12:32 PM
Whaleman's Avatar
Whaleman
When I had my Ebay Tire mounted I had the shop use bead sealer on both sides. Helps to keep the 60 psi in. Cleans up easy if it has to be dismounted. Dan
To Spare
