Having a hard time bleeding clutch
Old Jul 25, 2021 | 10:49 PM
J0hnalex's Avatar
J0hnalex
Cruising
Default Having a hard time bleeding clutch
Hello everyone just wanted to drop a quick thank you before I start this thread I know there’s probably one in existence but I can’t find a clear cut answer!
Everyone my name is Johnny and I’ve recently inherited my old mans 88 C4 a car I’ve been in love with since I was a kid. Unfortunately the cars been on jackstands for a few years and since my fathers passing I’ve really have put some effort into getting it back on the road we’re it belongs.
so I put a new clutch kit, clutch master and slave cylinder in. I bench bled the clutch master, and for the life of me can’t get any fluid out of the clutch master reservoir? I’ve disconnected the line on the back of the master I know I’m not air bound there. But dam I can’t get this slave to have fluid! I thought it was funny when I bought the part from AutoZone they said there was a note in the system that is hard to bleed!? But didn’t think this hard.
Any help would be appreciated, thank you in advance
​​​​​​-Johnny
Old Jul 26, 2021 | 02:25 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Your description can be interpreted several ways, so I'm going to ask this:
During your (attempted?) bench bleeding, were you able to able get fluid to flow out of the master cylinder (MC)? It sounds like you may not have....
If not, take the MC back and get another; it is faulty. This may be the simple answer to your problem.
Rebuilt, and even new, components are no guarantee that they are in perfect working conditions. The humans who assemble these things can, and do, make mistakes....and faulty components occasionally get past inspections and are not unheard of.
Old Jul 26, 2021 | 05:33 PM
J0hnalex's Avatar
J0hnalex
Cruising
yes I had fluid coming out of the master cylinder I even had fluid all the way down to the beginning of the slave cylinder. But I couldn’t get fluids through the slave!
Old Jul 26, 2021 | 08:16 PM
rocco16's Avatar
rocco16
So, you can't get the slave to accept fluid??
See if you can apply shop air to the slave's inlet. If the air then comes out of the open bleeder, it should work.
If no air comes out of the open bleeder, then you'll need a new slave cylinder.
Old Jul 27, 2021 | 05:21 PM
LiveWire1's Avatar
LiveWire1
Get a brake bleeder tool that uses a hand-held vacuum pump to draw fluid into the slave cylinder. Yes it's difficult to do this job.
One think I was told when I did mine was this:
Pump up your clutch as good as you can, and hold the pedal to the floor for 10 seconds or so. Then slide your foot sideways off the clutch pedal, which allows it to spring up into its resting position. Do it several times if you need. I don't know why it works, I don't care why it works. Just know, it works!
To Having a hard time bleeding clutch
