I have a 95 coupe - I had a leak somewhere which Chevrolet had to change the radiator. So I had it towed to them. Without the leak the car ran perfectly otherwise. Well when the radiator got switch they did an overall pressure test of the radiator system witch is pretty standard to do, but I hear it's not good to do with engines with high mileage (114,000). Well when completed and I got the car back white smoke was pouring out the tailpipe and it was basically un-drivable. Chevrolet was wanting to sell me a new engine for $9.000. No way being on SSDI I could afford a new engine. With it towed in I couldn't proved the engines was running perfectly when they got it. My question is now whether to have the headers redone or if I can just become deeper in the problem? If I attempted a header replacement what is the ball park figure for that type of replacement? If I have a chance I'd like to get my C4 running again but of course I have limited funds and save as I can.
So you would just change the gasket(s) if only one is blown, bolt on the old head(s) with 114000 miles and call it a day? Yes, you could and you might get lucky.....for awhile....
well but a set of valve seals and call it a day. It has anther 150k miles lest in it
Yes you could.....I was merely offering a suggestion to his possibly wanting to replace the heads if they turned out to be un-repairable or cost of fixing was greater than replacing.
The same conditions that eventually resulted in needing a new radiator probably weakened the head gaskets as well.
It is normal procedure to pressurize the system after making repairs to verify the repair work. But, if the gaskets (in this case) were already on the brink, they became the next thing that would have gone bad.
Failing a simple cooling system pressure test may have simply identified the next issue you would likely have, only this time you weren't stranded on the road somewhere!
Pulling the heads to replace head gaskets, etc., is well within the ability of most DIY'ers - or should be for anyone owning an older car!. You only need simple tools and a torque wrench you can borrow (e.g., from AutoZone) for free when you buy the gaskets! (They also can lend you or give you the option to purchase a coolant pressure test kit too!)
As for buying new heads or servicing the valve guides, etc., that may be unnecessary just to get back on the road. But, it falls into the realm of "while your in there": So, I can't fault anyone for going beyond gaskets to consider at least new seals if not also going for the upgraded heads. However, the $9000 reach to a new crate motor is pretty extreme, far as repair goes. But, again if it were for an LSx motor swap...? You could be dabbling in a 150+ HP increase too.
Putting heads on with valve seal sounds like a plan. My 87 may be leaky around the valve seals and I would like it increase compression. I will probably change the cam too in an attempt to get over 300hp. Thanks
To clarify, I would change heads to a higher compression configuration and it would clear up my leaky valve seals too. A new more aggressive cam to take advantage of the higher compression, but that is a lot more work.
I'm based on SSDI disability so I have limited funds - it will take me a while to save up the money. It appears that I need to replace a blown head gasket and a couple valve seals. Could someone be nice enough to give me a ballpark figure for what these should charge me? I have no idea? I want to make sure I can pay for the service and have enough cash.
machinist to ck the heads, seals? Surface, clean ck for cracks, ck valve job condition few hun+_
Labor have no clue. Post in your regional sec and here, maybe a member can do it for you and save you some. happens a lot here
Thanks a lot.
Ritchie
A set of head gaskets will run you around 50-100 bucks. A set of valve seals isn't even that much. Labor to replace them, if you can't do it, will run you around $800-1200.
IF I were in your shoes, as long as the heads were coming off the car, I'd have the heads checked for flatness, replace all the valve seals, and at least think about a fresh set of valve springs. Particularly if you're thinking about adding a cam in the future.
I live in Terre Haute - Indiana - Any members that could help - or give me a good place to take my Vette(95). while working I've always taken it to Chevy figuring they would take care of the vette. But I've lost faith when they wanted to charge me $9,000 to put in a new engine. Ran fine before getting my last support. And I mean it ran perfect!
