Solenoid/Starter or both?
Old Sep 22, 2021 | 01:53 AM
woodcrest's Avatar
woodcrest
Default Solenoid/Starter or both?
Just went to start my 89 C4 and nothing when I turned the key.
Luckily I was able to "bump start" the car.
Got home and starts fine.
So....solenoid/starter or both?
Car has about 125,000 miles, not sure if either has been replaced.
Never had any problems with the starter, seems to crank just fine.
Can the solenoid be replaced without removing the starter?
Old Sep 22, 2021 | 02:23 AM
ls777z's Avatar
ls777z
In a normal car you probably could, with a lot of colorful words, but it's only 2 more bolts, and a nut if you have the brace still, to drop it down to gain easier access.
You might also want to check the connections and battery cables.
Old Oct 2, 2021 | 05:02 AM
BowerPower's Avatar
BowerPower
The starter has a bad spot. For it to happen again, the starter would have to stop in the same spot again. It may not happen for months or it might happen everyday. I think it's the starter motor it self. If you wanted to try and save a dollar by doing just the solenoid, you can but the starter has to come off either way. You won't be saving yourself much money by just doing the solenoid.
Old Oct 2, 2021 | 10:53 AM
WVZR-1's Avatar
WVZR-1
Your '89 has a 'denso starter and IF original it would require likely just basic maintenance. Very straight forward 2 contacts, a plunger at higher mileage some might do brushes and more. Poster #3 thoughts are I'd think 'incorrect'. Research the 'denso starter before 'over-reacting'! Parts should be available locally and very dependent upon location a bench 'tune-up' should be inexpensive. Get starter in hand ID it to be either OE or a replacement before doing a thing!! If you generally do your own maintenance you should have no issues. If your starter can be confirmed to be OE you want to repair it - DO NOT EXCHANGE USING AS CORE!!! Even if you want to replace with reman 'keep the original'!
Old Oct 2, 2021 | 11:44 AM
BowerPower's Avatar
BowerPower
Considering I was a mechanic for years, my thoughts are not crazy. I know a thing or two because I have seen a thing or two. I would like an explanation as to why he needs to retain the original starter. He gonna spend 50-70 dollars in part to rebuild the original, not including the labor. When a re-man starter is the same money but less work. He's gonna do all that just to keep the original starter body. You want him to hored the original starter even if he doesn't keep it, why?
Old Oct 2, 2021 | 11:59 AM
WVZR-1's Avatar
WVZR-1
How about that!!!
I doubt very much you understand the 'denso starter the OP's '89 model Corvette was originally fitted with! If the OP is talented parts likely required for a 'quick fix' are less than $30 delivered! Likely less than $20 from a local vendor if he's fortunate!!
You didn't do well with spelling either! The word you're searching for is 'hoard' - A known original 'denso starter would likely bring as much or more than the reman the OP could purchase 'off the shelf'!
If the OP is fortunate and there's a 'local' shop that actually does builds and he asked that the contacts, plunger and brushes be replaced he could likely be 'out the door' for less than $50. It ain't 'hoarding' - it just makes good sense that if something has value - you don't just toss it! Even if the OP found his to be already a reman the contacts, plunger would likely get him running!
Old Oct 2, 2021 | 05:41 PM
BowerPower's Avatar
BowerPower
I get what you are saying especially since they don't make starters like they used but my argument is this...
1) if he replaces a couple of of parts now, is starter my work great for a little while or forever. Couple of months later, starter goes out again, this time it's a couple of other parts he didn't replace so now he has to take it off again and take it apart again.
2) if he takes of his his current starter and replaces all parts inside making it a functionally new starter. The cost of decent parts would put him in range of a reman that has a lifetime warranty and odds are will last a long time.
I was was bored at work and was searching to forum for no reason. Thought I could pass on some knowledge but it never fails that when I try to help on the corvette forum that an elitist has to speak up and say I'm an idiot. I don't get the mentality some people have.
Old Oct 2, 2021 | 05:48 PM
WVZR-1's Avatar
WVZR-1
Never mentioned 'idiot' - if you've knowledge regarding 'denso 'cranking motors' you wouldn't have made those comments! Now your back with more 'silliness' regarding 'lifetime' warranties! That for sure is silliness! The OP's '89 was delivered with a very solid cranking motor. Simple maintenance just works!
Bored at work? Find something to do for the guy that 'signs your check'!!!!
Old Oct 2, 2021 | 06:18 PM
BowerPower's Avatar
BowerPower
all you had to say was" the denso motor is very good and thats why he should keep it" I would understand. I metion the warranty on a new starter because if it has problems then there is no effort to get a replacement not because it's a better motor.
I work at a manufacturing plant. The job I was doing only needed my attention every 10 minutes. Thanks to the union, it is impossible to move up based on workmanship so I don't put in any more effort then my coworkers do.
Old Jun 15, 2022 | 02:54 PM
~ Anno Domini's Avatar
~ Anno Domini
Ignore this post. I posted in the wrong thread. I reposted in the "1989 Z51 starter" thread. TY.
Old Jun 15, 2022 | 04:33 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
Yeah, that original starter definitely should be kept. I kept mine and rebuilt it rather inexpensively. Stuck it in the box that the new Bosch one came in.
To Solenoid/Starter or both?
