Help a first time restorer!!
Old Nov 16, 2021 | 07:55 PM
ChiefsWithGuns's Avatar
ChiefsWithGuns
2nd Gear
Default Help a first time restorer!!
Sorry for the info dump, this is the first vehicle I’m attempting to bring back to life. In the attached pictures I will have parts that I’m unsure about. The first, which is a black box with multiple hoses running to it. It sits above the coolant temp sensor on the front of the engine. I have found a broken line, which I assume to be a vacuum line. It is a 90 with a square plug in. The second is a loose wiring harness toward the firewall, seen on the passenger side. I apologize if these questions have been answered but I am very new and not sure how to navigate the site yet.
Closeup of part
Part that the broken vacuum line goes too
Where the broken piece normally sits
Broken 90 with square connector
Loose wiring harness
Old Nov 17, 2021 | 04:27 AM
ls777z's Avatar
ls777z
the loose wire is probably for the temperature sending unit that is located in the head. you should be able to see it between the spark plugs.
