[QUOTE=Dascorpio2;1604637962]Is 89 vettes good? I'm looking at a 89 . convertible ..good condition with 132k. For 6500.00.......good deal?[/QUOTE
Hi, I own a 89, bright red, all the bells and whistles. I paid $13,000 for mine, was originally 16,000. Qualifier, it had 6,000 orginial miles, absolutely mint. Spent it’s entire life stored inside. Came from a collection. Do I feel I overpaid, not at all, love it. I would start. Bargaining at 4000 , easier to go up.
I’ve owned three 1989 Corvette, they’ve all been great cars. One of them I’ve owned since it was new, 33 years ago. To answer your question, you need to post pictures to help clarify what little description we have. Way too many variables, but it sounds pretty cheap right out of the gate
If every light, switch, gauges, accessories,etc, work, no major interior, mechanical or paint issues/body damage, then it probably is. But what are the odds of that ???
Here's my thoughts on it. If you look around longer and spend 2 grand more, you can find one with less than half the miles and better overall shape of what you're now looking at. I see too many guys buy a cheaper high mileage car and then try to smooth out the rough spots in it and have it turn into a money pit. Any upgrade or restoration of a Corvette isn't cheap. Set a budget and search until you find the best car, finally don't insult the seller with ridiculous low ball offers.
I own an '89 vette as well and can tell you from the inexpensive project car point of view I would have bought a more expensive already restored choice. I had to repaint, buy new seats, and replace a couple interior plastic pieces which I believe are the most expensive items to restore. I did do all the door/window seals and drive-line joints and bearings but those are inexpensive if you can do it yourself. Even engine is relatively inexpensive (if DIY) compared to paint/seats.
My next must have mint condition: you guessed it by now...paint and seats.
I would guess that at $6500 and 132k miles seats are probably worn but maybe most sections salvageable (total seat replacement usually $1200). Paint will run $2k for bare minimum crap to $5k for multi-base/multi-clear coats.
I have to go the opposite, if looking for a car to Drive, not just sit and look pretty. Cars age period, whether moving or not, especially in terms of certain materials, such as rubber. Rubber may look good when buying a car that's been sitting for years, but it will start to crumble when put in action.
Now, that's for a car sitting with little maintenance. Some low mileage will get careful, good maintenance, though again, rubber is still the common problem. Same could be said for a higher mileage car with little maintenance. So, a good thing to ask from the previous owner is maintenance records. Just changing the oil regularly is not enough.
Just to clarify my point of view. All Corvettes need maintenance, however I would think most of us would prefer a lower mileage car that's esthetically better looking over a high mileage car in rougher shape given the price isn't dramatically different.
I understand where you're coming from, just keep in mind "high mileage" and "rougher shape" don't always go together.
A low mileage that's been sitting in a barn, etc. A high mileage where the owner went to town, new paint, engine etc.
In general, maybe low mileage, though I tend to think no, since low mileage will need work unless it's going to sit some more.
I guess that I unfairly compare other Corvettes to mine. That said I can assure you my 89 with 23,000 miles does not need any " work " even though it's not driven as a daily driver. Low miles and great shape aren't the kiss of death some make it out to be.
