advice needed
Old Dec 30, 2002 | 10:23 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default advice needed
I am looking at a '96 C4 (to buy). I know cars, especially Chevys, but I've never owned a Corvette. This is my favorite body style. It drove fine and I've placed a deposit on it, but can always back out....
What should I be looking for when I inspect this vechicle again, other than the usual (fluids, clutch, general care, etc.)? i.e., are there any specific problem areas on this model that I should be aware of? If it makes a difference, it is a 6-speed coupe. Many thanks.
Larry
Old Dec 30, 2002 | 04:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: advice needed (rocco16)
One problem area on the LT1 cars is the famed opti spark; check the water pump for leakage.
Try the headlights and move the manual ***** to see if they are tight.
Have the wheel bearings checked as they are expensive items.
Put it on a rack and check for fluid leaks.
Inspect for rust on the metal frame members.
Take a CD along to check out the player.
Good luck with your ner Vette.
Old Dec 30, 2002 | 06:45 PM
Hamert's Avatar
Hamert
Also,
Pull the fuel rail covers and look to see if the intake manifold is leaking from the rear or from the front.
Check the weatherstrips around all the windows. It's about $800 to replace them all if you do it yourself.
And as Mr. Mojo would say, check the rear tires and make sure they have little or no tread so you know it was driven properly.
:D
Old Dec 30, 2002 | 08:05 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: advice needed (Hamert)
:D
:iagree:
Old Dec 30, 2002 | 08:19 PM
Miketheparrothead's Avatar
Miketheparrothead
Cruise-In V Veteran
St. Jude Donor '03-'06
Hey rocco welcome to CF :cool:
Old Dec 31, 2002 | 08:14 AM
rocco16's Avatar
rocco16
To those of you who replied, either with advice or a 'welcome', many thanks.
It's an LT-4, so no opti-spark, whatever that is (ignition control?).
Fluids look good, with no leaks. (some sludge in overflow, but radiator coolant and engine oil appear to be properly segregated....)
One spot of weatherstripping loose, on hatch corner (I can fix...)
I bought it!!
I am now one of you.
Next question: how do I disable that awful "1 - 4" shift feature??!!
Larry
:flag :flag
Old Dec 31, 2002 | 08:24 AM
Midnite 88's Avatar
Midnite 88
Welcome to the forum. You found the best place on the 'net for 'Vette advice and help. :cheers:
Congrats on the LT4 purchase. :cool:
Most of the fine vendors here carry the CAGS disabler.
ANd remember to :seeya
[Modified by Midnite 88, 8:27 AM 12/31/2002]
Old Dec 31, 2002 | 09:43 AM
Greg Johnson's Avatar
Greg Johnson
Welcome to the forum!
If you put it on a rack, make sure you do it where they know how to position the car on the rack. If nobody knows, make sure you dind out first. A lot of these cars get bunged up on the bottom because people don't know where to put the pads when they raise them up.
Greg :thumbs:
Old Dec 31, 2002 | 09:57 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
It's an LT-4, I bought it!!
:cool: Congratulations!! :cheers:
Old Dec 31, 2002 | 10:09 AM
rocco16's Avatar
rocco16
Default Re: advice needed (War Machine)
'Machine-
Thanks. Tell me more about the Crimson Armada. (mine is red.....)
Larry
Old Dec 31, 2002 | 10:19 AM
republicanhunk's Avatar
republicanhunk
Be sure to always disable your ASR. (The light will indicate when it has been properly disengaged) :steering:
Old Dec 31, 2002 | 10:26 AM
War Machine
rocco16, we have 2 red clubs.
One for the regular reds is the USS ZAD.
http://forums.corvetteforum.com/zerothread?id=56509
Or, if you have one of the dark red variety, we have the Crimson Armada.
http://forums.corvetteforum.com/zerothread?id=425256
Again, Congrats and enjoy your 96!! :cheers:
Old Dec 31, 2002 | 10:36 AM
rocco16's Avatar
rocco16
Thanks, 'Machine.
And thank you, Doug. I plan to turn off the traction control and wish I could disable the ABS. (I don't like the car doing the driving for me ... want to disable the CAGS, but can't find a friendly vendor link that can help me).
Other than a "I'll-do-it-MY-way-thankyou" attitude, is there another pertinent reason to disable the traction control??
Larry
Old Dec 31, 2002 | 02:45 PM
vettl83's Avatar
vettl83
Larry there are two ways to disable the CAGS, unplug the harness on top of the transmission and tape the connector end so you don't get dirt in it or have it programmed out of the ECM. I had mine progammed out with a custom chip burn but it's a 91. I believe the 96's do not run PROM chips so it has to be programmed out of the ECM. Good luck with your new ride. 84 CF 91 ZR-1
[Modified by vettl83, 7:47 PM 12/31/2002]
To advice needed
