Are build sheets available?
I gotta say, you guys are great, seems theres always someone foing out of their way to help out here Happy new year
John
:cheers:
Many, many thanks. Looks like this unit has had its share of warranty work, eh?
The build sheet is VERY informative!
What are inflateable seats???!!! I have inflateable lumbar supports on one of my other vehicles, but they have a little rubber bulb to inflate them with, this Corvette has no bulb that I can locate.
Larry I'll :seeya
On the right side of your console in the middle of your car there should be 3 rocker switches next to the switch for driver/passenger side seat controls. Those are what inflate and deflate the lumbar supports and move the side bolsters in and out.
EDIT: I noticed you don't have the AQ9 power driver AND passenger seats so I'm not sure about the rocker switches...??
Hope that helps!
Happy New Year!
Ted
[Modified by Hamert, 7:21 PM 12/31/2002]
John
:cheers:
No Vehicle Identification Number or Associated Open Campaign Information matching your entry was found.
The Vehicle Identification Number you entered is : 1G1YY0784G5108036
I guess not :(
Sorry.
[Modified by Hamert, 8:25 PM 12/31/2002]
I would also appreciate a code sheet and any dealer service info. Thanks for your help.
VIN# 1G1YY3181K5116520
90020 REAR WHEEL TIE RODS N/A Open
91058 SAFETY BELT RETRACTORS-LEFT SIDE N/A Open
91059 SAFETY BELT RETRACTORS-RIGHT SIDE N/A Open
93041 EVAPORATIVE EMISSION HOSE DETERIORATION N/A Open
No build info came up either. I guess the system isn't perfect.
What you get with the NCM, formerly Bowling Green Plant, Build Sheets is a physical replica of the actual build sheet, laminated I believe. You can also get a copy of the original window invoice/sticker, also laminated, I believe.
It's a nice way to support the NCM and get something for your $$$
:steering:
Warranty repair info:
03/24/1997 060613 # R0940 - RF SPEAKER RPL 33777 miles
04/01/1996 041318 # H2505 - ABS BRAK CONTR RPL 24368 miles
04/01/1996 041318 # K6550 - REGULATOR VALVE RPL 24368 miles
04/01/1996 041318 # R0480 - COMP POWER ASSY RPL 24368 miles
01/22/1996 037687 # J0667 - SERPENTINE BELT RPL 22611 miles
01/22/1996 037687 # R0940 - RF SPEAKER RPL 22611 miles
01/08/1996 036958 # J3480 - WATER PUMP/GSKT RPL 22340 miles
01/08/1996 036958 # K5100 - INDICATR NEEDLE RPL 22340 miles
01/08/1996 036958 # N3860 - W/S PUMP R&R/RPL 22340 miles
01/08/1996 036958 # Z7903 - 3-DAY COURTESY TRANSPORTATION 22340 miles
10/13/1995 032517 # N6278 - EFI WIRING REPAIR 20240 miles
10/13/1995 032517 # J0100 - RT EXH MANIFOLD REPLACE 20240 miles
10/13/1995 032517 # H0042 - DISC PADS R&R/RPL 20240 miles
06/08/1995 088922 # R0480 - COMP POWER ASSY RPL 15411 miles
06/08/1995 088922 # C3358 - L/F DR TRIM R&R/RPL 15411 miles
06/08/1995 088922 # E2020 - WHEEL ALIGNMENT - CHECK AND/OR ADJUST 15411 miles
03/02/1995 084079 # B2308 - ONE PIECE HATCH ROOF ASSEMBLY - RPL 12512 miles
03/02/1995 084079 # A1190 - RT FRONT DOOR BTWN BRK LINE & MLDG - REFINISH/CLEAR CT 12512 miles
11/10/1994 079124 # C1012 - FT ROOF W/STRIP RPL 8239 miles
11/10/1994 079124 # R9995 - CUST COMPLAINT NOT DUPLICATED 8239 miles
11/10/1994 079124 # C2510 - INST PNL COV PD RPL 8239 miles
10/25/1994 078331 # N9995 - CUST COMPLAINT NOT DUPLICATED 7940 miles
10/25/1994 078331 # C9995 - BODY INTERIOR - SYMPTOM DIAGNOSIS 7940 miles
09/13/1994 076222 # C2740 - CONSOLE PAD R&R/RPL 7413 miles
08/19/1994 075036 # C0221 - LEFT FRONT DOOR WINDOW - R&R OR REPLACE. 6314 miles
08/19/1994 075036 # C1012 - FT ROOF W/STRIP RPL 6314 miles
08/19/1994 075036 # N4800 - COMPUTER MODULE RPL 6314 miles
08/19/1994 075036 # D1440 - RT AIR DEFLECTR RPL 6314 miles
04/22/1994 068792 # N6170 - CRUISE WRG REP 2497 miles
Build sheet:
AC3
AK5 - SEAT, INFLATABLE, DRIVER & PASS
AR9 - FRT BKT, DELUXE
BGR - BOWLING GREEN, KY, USA
CF7 - SUN, REMOVABLE, NON-TRANSPARENT
C60 - AIR CONDITIONER FRT, MAN CONTRO
DL5 - ROADSIDE SERVICE INFORMATION
DL8 - LH & RH, REMOTE CONTROL, ELECTR
FE1 - SOFT RIDE GM1 - 2.59 RATIO
IP3 - INTERIOR DESIGN (P3)
JL9 - ANTILOCK
KG9 - 140 AMP
LT1 - GAS, 8 CYL, 5.7L, MFI, HO
MX0 - 4-SPEED AUTOMATIC TRANSMISSION
M30 - 4L60 AUTO TRANS
NB2 - EMISSION SYSTEM, CALIFORNIA TIER 0
NK4 - SPORT LEATHER
QB6 - 17 X 9, ALUMINUM, POLISHED
R7M - SALES ITEM NO. 38
UM6 - RADIO - AM/FM STEREO WITH UY5
U52 - INST, ELECTRONIC
U75 - POWER ANTENNA
V73 - USA/CANADA
XAA
YAA
YF5 - CALIFORNIA EMISSIONS
1AY - STOCK
1SA - OPTION 01
19I - BLACK (I) (96)
193 - BLACK LEATHER
75U - MEDIUM RED
Happy New Year,
Ted
Are you sure that's right? It should go back to '93 but it might be the fact that the production date on the car was probably in '92?
that may make it work. my car was build 2-07-93
thank you :cheers:
The warranty work looks very interesting. Would you mind running another?
1G1YY3380L5111341
:chevy
