Are build sheets available?
Old Dec 30, 2002 | 05:47 PM
Todbo's Avatar
Todbo
Default Are build sheets available?
seems that someone said that build sheets were available for the C4's , is there somewhere you can order them from , I'd like to know what options my car came with from the factory. Thanks guys :cheers:
Old Dec 30, 2002 | 05:50 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
Default Re: Are build sheets available? (Todbo)
The NCM offers copies of the build sheet and window sticker :)
Old Dec 30, 2002 | 06:36 PM
Hamert's Avatar
Hamert
Default Re: Are build sheets available? (thrills)
Yeah you can get them from NCM if you want to pay a whole bunch for them. Give me your VIN# and I'll post your build sheet here. :)
Old Dec 30, 2002 | 06:54 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
:iagree:
Old Dec 30, 2002 | 08:04 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Are build sheets available? (Zora)
The NCM offers copies of the build sheet and window sticker :) :iagree:
:iagree:
1-800-538-3883
NCM is a non profit organization, I would get it from them, no matter the price.
Old Dec 31, 2002 | 11:52 AM
Stv50's Avatar
Stv50
NCM gives you a very nice copy, laminated. A must have along with the window sticker. Looks good displayed at car shows
Old Dec 31, 2002 | 03:03 PM
Todbo's Avatar
Todbo
thanks guys , Hamert I'll have my vin in about a hour , thanks
Old Dec 31, 2002 | 04:21 PM
Hamert's Avatar
Hamert
Anytime. That's what we're here for :)
Old Dec 31, 2002 | 04:42 PM
Todbo's Avatar
Todbo
Default Re: Are build sheets available? (Hamert)
Hamert - 1G1YY22P0R5104398 thanks , ( i believe both are zero's, )
Old Dec 31, 2002 | 04:51 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Hamert-
Could I impose on you for the same favor??
Larry
Hamert's Avatar
Hamert
The only warranty work that shows up for your car is at 10k the brake pads were replaced as was the differential carrier. Here's the build sheet:
AC1
AC3 - SLIDING FRT DR, LH
AK5 - SEAT, INFLATABLE, DRIVER & PASS
AQ9 - FRT BKT, LUXURY
BGR - BOWLING GREEN, KY, USA
C2L - PACKAGE, DUAL REMOVABLE
C68 - ELECT AIR CONDITIONING
DL5 - ROADSIDE SERVICE INFORMATION
DL8 - LH & RH, REMOTE CONTROL, ELECTR
FE7 - FRT & RR, HD, VAR 3
FE9 - FEDERAL EMISSIONS
FX3 - AUTOMATIC ELECTRONIC CONTROLLED
GM3 - 3.45 RATIO
IL3 - INTERIOR DESIGN (L3)
J55 - ANTILOCK BRAKES
KG9 - 140 AMP
LT1 - GAS, 8 CYL, 5.7L, MFI, HO
ML9 - 6SPEED MANUAL 'ZF'
MN6 - MANUAL 6 SPD TRANS
NA5 - EMISSION SYSTEM, FEDERAL TIER 0
NK4 - SPORT LEATHER
QA1 - ALUMINUM WHEELS
R7A - SALES ITEM NO. 26
R7R - ADVERTISED SPECIAL VEHICLE
R8T - SALES ITEM NO. 69
UJ6 - LOW TIRE PRESS
UX0
U1F - AM/FM STEREO, SEEK/SCAN, AUTO R
U52 - INST, ELECTRONIC
U75 - POWER ANTENNA
V73 - USA/CANADA
XAU
YAU
Z07 - AGGRESSIVE SPORT
1AY - STOCK
1SB - PREFERRED EQUIP. GROUP - 1SB **
19I - BLACK (I) (96)
193 - BLACK LEATHER
28U - MIDNIGHT BLUE PEARL
64S - BRONZE, REMOVABLE PANEL
[Modified by Hamert, 4:59 PM 12/31/2002]
Old Dec 31, 2002 | 04:53 PM
Hamert's Avatar
Hamert
Default Re: Are build sheets available? (rocco16)
Sure Larry...no problem :)
Old Dec 31, 2002 | 05:09 PM
Tyler Townsley's Avatar
Tyler Townsley
Are you using a GM connected computer? I have some vins I need traced to see what they come back as:
Try 1G1YY2180J5100043
In spite of what it says I have the car and would like to try some others in that range.
This should give you a clue to what I am looking for.
Tyler http://temp.corvetteforum.net/clubs/...production.jpg
[Modified by Tyler Townsley, 5:11 PM 12/31/2002]
Old Dec 31, 2002 | 05:13 PM
Hamert's Avatar
Hamert
Default Re: Are build sheets available? (Tyler Townsley)
This is what it says:
No Vehicle Identification Number or Associated Open Campaign Information matching your entry was found.
Old Dec 31, 2002 | 05:18 PM
rocco16's Avatar
rocco16
what a great bunch of car enthusiasts!
Hamert, thanks....and how do you do it?
VIN 1G1YY2251T5120356
Larry :seeya
Old Dec 31, 2002 | 05:19 PM
Tyler Townsley
I guess this is a ghost then.
http://temp.corvetteforum.net/clubs/...useum_rear.jpg
Tyler
Old Dec 31, 2002 | 06:06 PM
Hamert's Avatar
Hamert
Larry :seeya
Here ya go Larry.
Your car was originally sold from Bob Stall Chevrolet in La Mesa, CA on 8/22/96. Here is the warranty work that has been done to it:
01/14/2002 192848 0 J4640 - MOTOR STARTER RPL 53068 miles
01/14/2002 192848 0 T2020 - WARRANTY TOWING 53068 miles
09/10/2001 183905 0 J3480 - WATER PUMP/GSKT RPL 49669 miles
09/10/2001 183905 # J4530 - DISTRIBUTOR RPL 49669 miles
06/14/1999 123083 # D0780 - A/C PROGRAMMER RPL 30664 miles
01/25/1999 113127 # J1420 - FLYWHEEL(MAN)RPL 27641 miles
01/11/1999 112083 # J3480 - WATER PUMP/GSKT RPL 27271 miles
01/11/1999 112083 # Z7904 - 4-DAY COURTESY TRANSPORTATION 27271 miles
01/11/1999 112083 # K0800 - CLUTCH DISC RPL 27271 miles
12/07/1998 109826 # J0200 - INTAKE GASKET RPL 26331 miles
01/07/1998 086519 # B2308 - ONE PIECE HATCH ROOF ASSEMBLY - RPL 17991 miles
10/01/1997 080412 # K2720 - TRANSMISSION RPL 15909 miles
10/01/1997 080412 # Z7901 - 1-DAY COURTESY TRANSPORTATION 15909 miles
02/17/1997 065750 # R0830 - CD PLAYER-RETURN TO AC-DELCO-REMOVE & REPL CD PLAYER 8345 miles
01/31/1997 064760 # J0200 - INTAKE GASKET RPL 7958 miles
09/17/1996 081279 # J0200 - INTAKE GASKET RPL 1207 miles
And here is the build sheet:
AG1
AG2 - ADJUSTER, 6-WAY POWER SEAT,
AR9 - FRT BKT, DELUXE
CF7 - SUN, REMOVABLE, NON-TRANSPARENT
FE1 - SOFT RIDE
GM3 - 3.45 RATIO
IP3 - INTERIOR DESIGN (P3)
KG9 - 140 AMP
LT4 - 5.7 LITRE V8 HIGH PERF
NB6 - EMISSION SYSTEM, CALIFORNIA TIER 1
NG5 - EMISSION, CERTIFICATION, FIFTY
NK4 - SPORT LEATHER
QB6 - 17 X 9, ALUMINUM, POLISHED
UX0
U75 - POWER ANTENNA
VG6 - BUMPER IMPACT, 5 MPH, CALIFORNI
VG8 - LABEL, NOTICE TO BUYER
V73 - USA/CANADA
XAA
YAA
YF5 - CALIFORNIA EMISSIONS
1AY - STOCK
193 - BLACK LEATHER
70U - EXTERIOR, TORCH RED (91)
I could tell you how I do it, but then I would have to kill you...
:lol: :lol:
Just kidding.
I have access to the GM dealer database.
Hope this helps you.
Ted
To Are build sheets available?
Old Dec 31, 2002 | 06:09 PM
Hamert's Avatar
Hamert
Tyler
Tyler,
I tried VIN#'s one up and one down from yours and also ending and 01 and 99 and they all came up the same. Sorry.
Ted
Old Dec 31, 2002 | 06:48 PM
Todbo's Avatar
Todbo
Hamert , thanks next time you get to Memphis I'll buy you a cold one :cheers: that build sheet hit the spot , I now know the rear end gear ratio and the Z07 suspension package :D
Old Dec 31, 2002 | 06:58 PM
rocco16's Avatar
rocco16
Hamert-
Many, many thanks. Looks like this unit has had its share of warranty work, eh?
The build sheet is VERY informative!
What are inflateable seats???!!! I have inflateable lumbar supports on one of my other vehicles, but they have a little rubber bulb to inflate them with, this Corvette has no bulb that I can locate.
Larry I'll :seeya
