Single Mass Flywheel Setup with NO CHATTER
Not sure how accurate this is but I thought I'd pass it along.
If its gone or worn Id get a nice mid weight Steel flywhee. 30 lbs give or take
Good shift recovery, lighter than stock and with a simple organic disc should have excellent manners no chattering
Whatever kit has a good Throwout bearing grab it. Most are made in china and will fail..I think it hurts the appeal of manual vettes
Rebuilds are crazy $..sure theres something good out there still.
If you are instead referring to the “rocks in a can” sound from the ZF when in neutral with clutch released (or when lugging) that’s the biggest “risk” in dumping the DMF. It’s harmless and there is a shim kit for the countershaft that helps reduce or eliminate. Once my car is warmed up and the trans is nice and warm too I get this sound but it’s not terrible, even with the shim kit/steel FW I have that sound.
Just make sure you go steel FW and organic disk, and if you go with the stock pull type have the PP true’d up.
@pedricd so you have the shim kit and are you using the Ram conversion setup with the push style PP and you still have the rocks in a can noise?
The countershaft shim kit tries to take up/eliminate excess play in the countershaft to reduce and/or eliminate the potential of this "gear rattle". You may go to SMF and do no shims and have no "gear rattle", especially with a steel flywheel (heavier than aluminum)....in other words YMMV.
Exactly... not a big deal... and completely harmless. It's not chatter, it's "gear rattle" due to the countershaft. Chatter or Shudder is specific to what happens when engaging the clutch in gear and the clutch grabs/slips/grabs/slips/grabs/slips...it shakes the car. and usually starting off in 1st or reverse, it CAN be harmless or even expected especially with an aggressive clutch and light flywheel. A *stock* setup or stock similar (steel fw with organic disk) it should not happen. "Gear rattle" is just a sound.
For what it's worth as a single data point, I'll offer my personal experience. I installed Spec's extra-weight billet steel SMF, as well as their PP and Stage 2 disc, into my '94 LT1 car. I did this work 12 years ago, before hearing of the shimming trick that Bill B (ZF Doc) had developed. It's possible he hadn't even developed it yet at that time, but in any case, I was unaware of it. The result in my case has been very satisfactory. I have barely-audible gear noise at idle with the clutch engaged. It is so slight that I drove the car for several years before I even noticed it. Nobody has ever commented on it, so I presume nobody else has noticed it. I believe that the added inertia of the extra-weight SMF contributes much to knocking down the rotational pulses in the rotating assembly. I've been very pleased with the outcome, and am happy to have the DMF out of the car before it failed. The Stage 2 clutch chatters a bit when stone-cold, which I attribute to its disc's Kevlar friction surfaces. After the first or second engagement on each outing, the engagement is nice and smooth.
There have been many posts here in recent years about a lack-of-parallelism problem with the manufacture of all of the currently-available pressure plates. Bill B is offering to clean these up for customers, prior to their being installed. If I were doing a clutch on a ZF C4 today, I'd take him up on that, and also do the countershaft shimming. And, I'd still go with an extra-mass SMF.
YMMV.
Live well,
SJW
Good luck with the job. Let us know how it goes.
Live well,
SJW
