Wind noise
Old Oct 7, 2022 | 07:43 PM
AftonJay's Avatar
AftonJay
Default Wind noise
So my car makes a wierd whistling noise, it is coming from back edge of targa. It reminder my of blowing across a bottle but on steroids. It happens at high speeds and seems temp dependent. Happens at lower speed the hotter it is or if car sits in sun. Any ideas ?
Old Oct 7, 2022 | 08:12 PM
THE 383 admiral's Avatar
THE 383 admiral
What condition are the targa seals. How old?
Try adding material along the targa seals.
Bolt it back down. Take another cruise.
Old Oct 7, 2022 | 08:41 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If the seal is dry, coat it with seal lube/coating.
If top is a bit "loose", adjust the latch to pull down the rear of the top a tad more..
Old Oct 8, 2022 | 10:09 AM
AftonJay's Avatar
AftonJay
Thanks, I will try the adjustment. The seal seems to be in good shape. Nice shape, still soft.
To Wind noise
