Looking at a 1990 Convertible
So... with that said... is 172K something to RUN AWAY from? My gut feeling from being driving for the last 45 years is to stay away from ANYTHING with that many miles but most of the vettes around here that are L98 powered all have super high mileage on them. Neither car was original owner, neither car has any service or maintenance records but both cars are really clean. The only things I know that were replaced on the 1990 with 172K on it is the top is new, it has an aftermarket exhaust that sounds amazing and it has brand new Eagle F1 tires on it but the clutch is original with 172K on it!!! . Any suggestions or advise is appreciated.
https://bringatrailer.com/listing/19...t-corvette-54/
https://bringatrailer.com/listing/19...t-corvette-57/
https://bringatrailer.com/listing/19...orvette-coupe/
https://bringatrailer.com/listing/19...t-corvette-46/ (Callaway-cheap in my book!)
https://bringatrailer.com/listing/19...t-corvette-41/
Have the owner stater the car COLD while you stand out back and watch for unusual smoke/color from the tail pipes. Look at all the fluids, have they been flushed and kept up or is everything muddy, look at the serpentine belt, wear is one thing, looking like its original to the car is another. Get on your hands and knees and look at the front tires. Are they wearing even or are the wheel bearings shot? You get the idea. I've bought plenty of cars with over 100k miles on them and walked away from 60k miles cars. Good luck!
It is just shocking to me that any 1990 C4 Vette with a 6 speed could have the original clutch at 160K to 170K miles. It doesn't even seem possible. With regular oil changes and maintenance a 350 block could last for upwards of 250K but a 6 speed in a Vette I would think 80K to 100K would top of the mark.
My old Vette was a 77 C3 with an M21 Muncie 4spd. It had 80K on it. The clutch went at 78K and was replaced. I understand that the ZF6 clutch is a hydraulic clutch. Is that the reason they last so long? I thought the hydraulic part of the clutch was just to ease the pressure required in depressing the clutch pedal making it easier to use.
Does the hydraulic part aid in extending the life of the clutch itself? Or is it the CAGS. Both cars clutches grabbed nice and low and I assumed that means the clutch in both cars is good but I read that even if the ZF6 clutch is on its last legs it will still grab low as if it was new.
Where are you located? Lower mile versions (100k ish or less) of exactly what you are looking for seem to pop up around me fairly regularly (Ohio/MI) and two recently for SUB 6k.
Oh and “nice and low” can be a bad thing. If the hydraulics are failing and have air in them, the engagement moves closer and closer to the floor. C4s tend to have a fairly high engagement point anyway… it makes it very hard to judge. The absolute best way is to put it in 5th at a slow speed and hammer it to see if it slips. Everything else is guessing.
Honestly you care more about leaky hydraulics or poor synchro engagement…that’s the trans killer.
