Need shop to replace clutch.
I'm in the Washington DC area. I want to replace the entire clutch system in my 96CE.
Do you all know of a one-stop-shop that offers the parts (including flywheel) and installation?
I understand the FW will be converted.
I'm looking for a stock equivalent setup. I don't drag race.
Thank you,
Ric
Thread from 2012 - https://www.corvetteforum.com/forums...n-dc-area.html
https://www.coopercorvettes.com/service-department
https://www.criswellcorvette.com/service-department
https://www.tonyscorvetteshop.com/
the are humming noises too when at steady speed on the highway. Something very concerning as well is the high level of vibrations I get after 2500 RPMs, especially under heavy throttle.
I just replaced the motor mounts and although the drivers side was cracked, they did fix the vibrations issue.
Thanks for the recommendations. I didn't realize I had 2 really good shops ( based on reviews) so close to me.
To be clear, I replaced the mounts as part of my program to update and replace 26 year old parts on this car. I did the work myself and figured I might be able to kill two birds with one shot regarding the mounts and vibrations.
Edit: on my previous post I meant to say the new mounts DID NOT fix the vibrations issue.
