Winter Storage
Old Dec 17, 2022 | 01:02 PM
PoloGreen’95's Avatar
PoloGreen’95
Default Winter Storage
My friend is storing his vette for the winter by first using a basic fabric cover, and then covering that in a large tarp and using bricks to hold it down. He says it keeps the car extremely dry. I have heard people not like tarps but this does not seem like a bad idea.
What do you think? Good or bad for the car?
Better than using just a quality cover?
Old Dec 17, 2022 | 02:34 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
If I couldn’t keep the car inside I wouldn’t have it. He doesn’t know anyone anywhere he can store the car ?
Old Dec 17, 2022 | 02:39 PM
SmokinBlack's Avatar
SmokinBlack
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
C4 of Year Finalist (stock) 2019
St. Jude Donor '08
I don't like a tarp anywhere near the paint on a car if it is even remotely decent. If there is a quality cloth cover under it, it may be OK, but otherwise they will rub and scuff the paint from movement in the rain, snow, and wind.
Old Dec 17, 2022 | 03:09 PM
PoloGreen’95
Originally Posted by IHBD
Parked on dirt (gravel) with a moisture barrier cover is a recipe for significant corrosion formation on aluminum and ferrous components. The ground is warmer than the components, and moisture will condense on the colder metals.
I have stored cars long-term on dirt, but I laid down a tarp on the dirt, put the car on it and folded up the 4 sides. Then covered the car, overlapping the first tarp so water couldn't get in the ground tarp and under the car. Several years later, I was pleased with the results, there was very little deterioration.
So if this car was parked on asphalt, perhaps it would be a better strategy?
Old Dec 17, 2022 | 03:11 PM
PoloGreen’95
I am with you on that, but both me and him have encountered a situation where we will have to store the cars outside for a bit before we can get another garage. It hurts to have the cars outside, but we’re trying our best to protect them. I bought a $500 coverking cover that has been impressive so far.
Old Dec 17, 2022 | 03:25 PM
SEVNT6's Avatar
SEVNT6
The last thing I'd do is put on that tarp. The only thing it's going to do is trap moisture.
A good outdoor car cover will breathe and can be water resistant too...
Old Dec 18, 2022 | 07:16 AM
Incorvettei's Avatar
Incorvettei
As others have stated this is not a good plan. Tarps are not made to cover cars
Old Dec 18, 2022 | 04:00 PM
CorvetteRules's Avatar
CorvetteRules
Your friend should just get a good fabric cover and drive it all winter. No reason not to, just don't drive it after a snow event until road salt has been washed away. Was 37 degrees today and had to run to Home Depot and since I wasn't needing 2x4's I jumped it the Corvette for a fun ride. Easy decision, take the crew cab Ram or the Corvette.
Old Dec 18, 2022 | 04:26 PM
Natty C's Avatar
Natty C
At the very least, it'd be wise to get it on a solid surface, rather than the gravel.
If it were me, I'd pour a concrete pad and build a barn for it.
It don't need to be big. Just big enough to get around in with the doors open.
To Winter Storage
